Well it look like the 4550 and this chip are a little different in the way they need to accesss the registers for some USB stuff. In the data sheet for this chip it says that "addresses F40 through F5F are not part of the Access Bank. therfore specifying a BSR should be used to access these registers". I am not sure how to so this . Any help would be greatly appreciated.. Thanx
Posted: Sat Nov 10, 2007 4:44 pm
Got it.. Did not have to do anythinghere.. On the 4550 the PLL turns itself on . On the 87j50 you have to set it on manually. Yeh.. TTY
