12F675 - Interrupt does not work
40inD
PostPosted: Thu Oct 04, 2007 5:12 am     Reply with quote
I make an intellectual seat heater for my car. Here is the schematic:
When I turn the RV1 an interrupt must occur. But it does't. Where is my mistake?
Here is the code:
#include <12F675.h>
#device adc=8
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOPUT                    //No Power Up Timer
#FUSES BANDGAP_HIGH
#define HEATER PIN_A2
#define GREEN PIN_A1
#define RED PIN_A5
short int was_off;
int mode=0, oldmode=0;
int16 count; //max 7200 for 30 min
#int_RA
void  RA_isr(void)
mode=read_adc();
count=0;
   setup_adc_ports(sAN0|VSS_VDD);
   setup_adc(ADC_CLOCK_div_4);
   enable_interrupts(INT_RA);
  while (1)
  { //mode=read_adc();
  if (mode>250)
    mode=255;
  if (mode<10)
    mode=0;
 if(mode!=oldmode)        //regulator was changed
  if (was_off)       //2 min full power after start
  { if (count<240){                        //maximum setting
            output_high(heater);
            output_low(GREEN);
            output_high(RED);
            delay_ms(250);
            was_off=false;
  if(count<=7200)
   switch (mode)
    case 0: {    //minimum setting
            output_low(heater);
            output_low(GREEN);
            output_low(RED);
            delay_ms(255);
    case 255: {  //maximum setting
            output_low(GREEN);
            output_high(RED);
            delay_ms(255);
   default:
   output_high(heater);  //------------/
   delay_ms(mode);       //low-freq PWM/
   output_low(heater);   //- T=255ms  -/
   Delay_ms(255-mode);   //------------/
   if ((mode>10)&&(mode<=80))
      output_high(GREEN);
      output_low(RED);
     if ((mode>80)&&(mode<=160))
      output_high(GREEN);
      output_high(RED);
     if (mode>160)
      output_low(GREEN);
      output_high(RED);
Count++;
   if(count>7200)         // turn all off after 30 min of inactivity
    output_low(heater);
    output_low(GREEN);
    output_low(RED);
    oldmode=mode;
    was_off=true;
    sleep();
[/code]
adrian
PostPosted: Thu Oct 04, 2007 5:39 am     Reply with quote
INT_RA refers to a digital change on the input pin - not analogue.
40inD
PostPosted: Thu Oct 04, 2007 5:52 am     Reply with quote
OK, I turn it from min to max (from 0 to 5V) - it is a digital change. No effect.
PostPosted: Thu Oct 04, 2007 6:00 am     Reply with quote
You need the pin to be set as a digital input. As soon as you program it for analog, interrupts are no longer available on the pin. Doesn't matter what voltage you apply, if it is analog, there is no interrupt input.
If (for instance), you wanted an interrupt when the voltage rose above a digital level, while still performing analog input, then connect the signal to GP3 as well, and use 'INT_RA3'. This will occur when the signal changes beyond the digital thresholds, and you can read the voltage on RA0, with the analog statements.
