Varitronix VIM-332-DP LCD Driver
deltatech
PostPosted: Wed Sep 05, 2007 6:41 pm     Reply with quote
Hi Does any one have a CCS Driver For Varitronix VIM-332-DP LCD .
I have a Driver That came with PICDEM KIT but it is an lcd.asm file I dont know how use it with CCS . Any advice much appreciated and many Thanks in Advance
PostPosted: Wed Sep 05, 2007 7:04 pm     Reply with quote
There are at least six different Microchip boards that start with "PICDEM".
What's the full name of your board ?
deltatech
My Board is PICDEM Mechatronics
PostPosted: Thu Sep 06, 2007 9:10 am     Reply with quote
Hi PCM programmer My Board is PICDEM Mechatronics it has a 16F917 PIC
PostPosted: Thu Sep 06, 2007 11:51 am     Reply with quote
This is a drawing of the LCD.
http://www.varitronix.com/Product/LCD/VIM-332-DP(R0).pdf
It has 4 "commons" and 10 segment lines. The pin connections
are listed on page 6.
The ASM code in the Microchip LCD driver file would have to be
translated to use the CCS LCD functions. Here's one post where
I tried to help someone figure out the CCS example file, Ex_LCD92.c:
http://www.ccsinfo.com/forum/viewtopic.php?t=30748
The 16F917.h file lists the constants that can be used with the setup_lcd()
function. Since your LCD has 4 "commons", you would use the
LCD_MUX14 constant in setup_lcd().
If you're new to C and electronics and LCDs, this is not going to be easy.
