Hi Does any one have a CCS Driver For Varitronix VIM-332-DP LCD .
I have a Driver That came with PICDEM KIT but it is an lcd.asm file I dont know how use it with CCS . Any advice much appreciated and many Thanks in Advance
Posted: Wed Sep 05, 2007 7:04 pm
There are at least six different Microchip boards that start with "PICDEM".
What's the full name of your board ?
deltatech
My Board is PICDEM Mechatronics
Posted: Thu Sep 06, 2007 9:10 am
Hi PCM programmer My Board is PICDEM Mechatronics it has a 16F917 PIC
The ASM code in the Microchip LCD driver file would have to be
translated to use the CCS LCD functions. Here's one post where
I tried to help someone figure out the CCS example file, Ex_LCD92.c:
http://www.ccsinfo.com/forum/viewtopic.php?t=30748
The 16F917.h file lists the constants that can be used with the setup_lcd()
function. Since your LCD has 4 "commons", you would use the
LCD_MUX14 constant in setup_lcd().
If you're new to C and electronics and LCDs, this is not going to be easy.
