eeprom writing problem
deepakomanna
View user's profile Send private message AIM Address Yahoo Messenger
PostPosted: Thu Aug 30, 2007 3:23 am     Reply with quote
Dear Sir,
here i am using 16f913, MPLAB 7.5 Ver. & CCS PCM C Compiler, Version 3.249, 34534.Also i am testing this using ICD 2.
Actually here i am facing problem for eeprom writing.
In timer0 interrupt routine i am storing data to eeprom every 6 sec(only for testing later it will be in houres).
Here the number should have to increment after 3 sec.And the incremented number should have to display on glass LCD.
if i declared the following statement in timer0 interrupt routine,the number is incremented after several minutes.
#INT_TIMER0
void timer0_isr(void)
// interrupt routine for 25 msec
sec_count++;
if(sec_count == 240)
      //write data every 6 sec to eeprom.
      ee_write32(eeprom_address, number); //write data to EEPROM loc 0x00
      sec_count = 0;
Another way i tried this,if i declare the following statement after the number++; it works as per logic.
if(min_count == 3)      // if frequency is 337 Hz, min_count == 3, becomes after 3 sec.
         {               // so number is incremented after 3 sec.
            number++;
// =======  if eeprom write declared here,itworks as per specification ===============
//            ee_write32(eeprom_address, number); //write data to EEPROM loc 0x00
            if(number == 999999)
               number = 0;
            min_count = 0;
so help me to sort out this problem. here is my full code..if any quries let me know
#include<16F913.h>
#fuses INTRC_IO,NOWDT,PUT,/*****/MCLR,/****/NOPROTECT,NOCPD,NOBROWNOUT,NOIESO,NOFCMEN   //external MCLR bcz of MPLAB ICD2
#use delay(clock=8000000)
//                                 LCD Configuration                                   //
// Digit segments    A              B              C              D              E              F              G           DP
//                         b7             b6             b5             b4             b3             b2            b1             b0
#define DIGIT1  COM3+6,   COM2+6,   COM0+6,   COM1+6,   COM0+5,   COM3+5,   COM2+5,   COM1+5      // DISPALYS FROM RIGHT SIDE
#define DIGIT2  COM3+7,   COM2+7,   COM0+7,   COM1+7,   COM0+4,   COM3+4,   COM2+4               // DISPALYS FROM RIGHT SIDE
#define DIGIT3  COM3+8,   COM2+8,   COM0+8,   COM1+8,   COM0+3,   COM3+3,   COM2+3               // DISPALYS FROM RIGHT SIDE
#define DIGIT4  COM3+9,   COM2+9,   COM0+9,   COM1+9,   COM0+2,   COM3+2,   COM2+2                  // DISPALYS FROM RIGHT SIDE
#define DIGIT5 COM3+11,   COM2+11,   COM0+11,   COM1+11,   COM0+1,   COM3+1,   COM2+1                  // DISPALYS FROM RIGHT SIDE
#define DIGIT6 COM3+12,   COM2+12,   COM0+12,   COM1+12,   COM0+0,   COM3+0,   COM2+0                  // DISPALYS FROM RIGHT SIDE
#define VLCD_ENABLE 0x10
#define BLANK 0
#define DOT 1
#define eeprom_address 0
//character                     0         1        2         3        4        5        6         7       8        9
byte const Digit_Map[10] = {0xFC,0x60,0xDA,0xF2,0x66,0xB6,0xBE,0xE0,0xFE,0xF6};
byte lcd_pos;
byte segments;
void init_CPU();
int32 ee_read32(int16);
void ee_write32(int16,int32);
int16 sec_counter = 0;
int16 min_count = 0;
int32 number = 0;
int1 flag = 1;
int1 flag2 = 0;
int8 i = 0;
int16 sec_count;
void lcd_putc(char c)
 if(c=='\f')
     lcd_pos=0;
else {
           if((c>='0')&&(c<='9'))
                  segments=Digit_Map[c-'0'];
               segments=BLANK;
      switch(lcd_pos)
          case 1:  lcd_symbol(segments,DIGIT6); break;     // fill 1s place
         case 2:  lcd_symbol(segments,DIGIT5); break;      // fill 10s place
              case 3:  lcd_symbol(segments,DIGIT4); break;     // fill 100s place
             case 4 : lcd_symbol(segments,DIGIT3); break;     // fill  1000s place
              case 5 :if(flag2 == 1)
                        lcd_symbol(segments,DIGIT2); break;      // fill  10000splace
                case 6 :
                    if((flag == 1))
                           lcd_symbol((DOT |segments),DIGIT1);    // fill  100000s place
                           lcd_symbol(segments,DIGIT1);
                         if(number <10)
                               flag2 = 0;  // flag2 here is used to display 0.0. If we not used this data displayed is only 0 till it reaches to 10.
                               lcd_symbol(Digit_Map[i],DIGIT2);
                            flag2 = 1;
 lcd_pos++;
#int_ccp1
void ccp1_isr(void)
   // ccp1 interrupt is used to measure the count between two rising pulses. Here we
   //are connected frequency generator to pin no 16 of 16f913
sec_counter++;
if(sec_counter >= 337)
      flag =~flag;      // compliment flag for decimal point.
      sec_counter = 0;
      min_count++;
         {               // so number is incremented once after 3 sec.
            number++;
               number = 0;
            min_count = 0;
//set_timer1(0);
#INT_TIMER0
sec_count++;
// Declaration of eeprom write here will take more time to increment the number.....
      sec_count = 0;
init_CPU();
            number = ee_read32(eeprom_address); //read data from EEPROM loc 0x00
            printf(lcd_putc,"\f%6lu",number);
int32 ee_read32(int16 base_address)
int8 j;
int32 data_read;
for(j=0; j<4; j++)
   *(&data_read+j) = read_eeprom(base_address+j);
return (data_read);
void ee_write32(int16 base_address ,int32 data)
int8 j;
for(j=0; j<4; j++)
   write_eeprom(base_address+j,*(&data+j));
void  init_CPU()
/**************  PORT SETTINGS ****************/
   PORT_B_PULLUPS(0XC0);      // RB7 & RB6 i/p for programming devices.
   SET_TRIS_A(0X80);         //
   SET_TRIS_B(0XC0);
   SET_TRIS_C(0X27);         //VLCD 1,2,3 i/p
   SET_TRIS_E(0X08);         // RE3 i/p for programming the device.
/*************** LCD SETTINGS ********************/
   SETUP_LCD( LCD_MUX14 |LCD_INTRC|VLCD_ENABLE, 2);
/****************  COMPARATOR SETTINGS  ***************/
   SETUP_COMPARATOR(NC_NC_NC_NC);
/****************  INTERRUPT SETTINGS  *****************/
   ENABLE_INTERRUPTS(GLOBAL);
   ENABLE_INTERRUPTS(INT_TIMER0);      //enable timer1 interrupt
   SET_TIMER0(61);                     // timer0 interrupt for 25 msec.
   SETUP_TIMER_0(RTCC_INTERNAL|RTCC_DIV_256);
set_timer1(0);
 setup_ccp1(CCP_CAPTURE_RE);       //Capture on rising edge
clear_interrupt(INT_CCP1);
enable_interrupts(INT_CCP1);
setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);
Thank You,
With Best Regards,
Deepak.
rnielsen
PostPosted: Thu Aug 30, 2007 8:26 am     Reply with quote
I only looked at your code quickly but I noticed one thing.
int8 j;
for(j=0; j<4; j++)
This part only has 256 bytes of eeprom inside of it. You have declared your addressing as a 16 bit value. This can only be an 8 bit value. You can only write one byte at a time, also. You have declared this as a 32 bit value. Things aren't going to be compatible this way. When your address goes above 255 it will start over-writing the eeprom at address 0 again. Your 32 bit variable will only be saving the lowest 8 bits of data.
Ronald
deepakomanna
PostPosted: Thu Aug 30, 2007 9:51 pm     Reply with quote
Thanks for notifieng this,
After this i have changed
int16 base_address to int8 base_address
And i want to store 32 bit data so i choosed
int32 data
still the problem is not solved.
any help appriciated
Thank You,
With Best Regards,
Deepak.
rnielsen
PostPosted: Fri Aug 31, 2007 8:51 am     Reply with quote
You will need to write one byte at a time. You could pass the 32bit variable to ee_write32() and then shift/mask the data, inside of the function, so you can save each 8bit portion of it. You will need to re-construct the variable when you read it from the eeprom.
Keep in mind that you will only have enough room to store 64 - 32bit variables this way since each one will take 4 bytes of space.
Ronald
