deepakomanna
eeprom writing problem |
Posted: Thu Aug 30, 2007 3:23 am |
Dear Sir,
here i am using 16f913, MPLAB 7.5 Ver. & CCS PCM C Compiler, Version 3.249, 34534.Also i am testing this using ICD 2.
Actually here i am facing problem for eeprom writing.
In timer0 interrupt routine i am storing data to eeprom every 6 sec(only for testing later it will be in houres).
Here the number should have to increment after 3 sec.And the incremented number should have to display on glass LCD.
if i declared the following statement in timer0 interrupt routine,the number is incremented after several minutes.
Code: | #INT_TIMER0
void timer0_isr(void)
// interrupt routine for 25 msec
sec_count++;
if(sec_count == 240)
//write data every 6 sec to eeprom.
ee_write32(eeprom_address, number); //write data to EEPROM loc 0x00
sec_count = 0;
Another way i tried this,if i declare the following statement after the number++; it works as per logic.
Code: | if(min_count == 3) // if frequency is 337 Hz, min_count == 3, becomes after 3 sec.
{ // so number is incremented after 3 sec.
number++;
// ======= if eeprom write declared here,itworks as per specification ===============
// ee_write32(eeprom_address, number); //write data to EEPROM loc 0x00
if(number == 999999)
number = 0;
min_count = 0;
so help me to sort out this problem. here is my full code..if any quries let me know
Code: | #include<16F913.h>
#fuses INTRC_IO,NOWDT,PUT,/*****/MCLR,/****/NOPROTECT,NOCPD,NOBROWNOUT,NOIESO,NOFCMEN //external MCLR bcz of MPLAB ICD2
#use delay(clock=8000000)
// LCD Configuration //
// Digit segments A B C D E F G DP
// b7 b6 b5 b4 b3 b2 b1 b0
#define DIGIT1 COM3+6, COM2+6, COM0+6, COM1+6, COM0+5, COM3+5, COM2+5, COM1+5 // DISPALYS FROM RIGHT SIDE
#define DIGIT2 COM3+7, COM2+7, COM0+7, COM1+7, COM0+4, COM3+4, COM2+4 // DISPALYS FROM RIGHT SIDE
#define DIGIT3 COM3+8, COM2+8, COM0+8, COM1+8, COM0+3, COM3+3, COM2+3 // DISPALYS FROM RIGHT SIDE
#define DIGIT4 COM3+9, COM2+9, COM0+9, COM1+9, COM0+2, COM3+2, COM2+2 // DISPALYS FROM RIGHT SIDE
#define DIGIT5 COM3+11, COM2+11, COM0+11, COM1+11, COM0+1, COM3+1, COM2+1 // DISPALYS FROM RIGHT SIDE
#define DIGIT6 COM3+12, COM2+12, COM0+12, COM1+12, COM0+0, COM3+0, COM2+0 // DISPALYS FROM RIGHT SIDE
#define VLCD_ENABLE 0x10
#define BLANK 0
#define DOT 1
#define eeprom_address 0
//character 0 1 2 3 4 5 6 7 8 9
byte const Digit_Map[10] = {0xFC,0x60,0xDA,0xF2,0x66,0xB6,0xBE,0xE0,0xFE,0xF6};
byte lcd_pos;
byte segments;
void init_CPU();
int32 ee_read32(int16);
void ee_write32(int16,int32);
int16 sec_counter = 0;
int16 min_count = 0;
int32 number = 0;
int1 flag = 1;
int1 flag2 = 0;
int8 i = 0;
int16 sec_count;
void lcd_putc(char c)
if(c=='\f')
lcd_pos=0;
else {
if((c>='0')&&(c<='9'))
segments=Digit_Map[c-'0'];
segments=BLANK;
switch(lcd_pos)
case 1: lcd_symbol(segments,DIGIT6); break; // fill 1s place
case 2: lcd_symbol(segments,DIGIT5); break; // fill 10s place
case 3: lcd_symbol(segments,DIGIT4); break; // fill 100s place
case 4 : lcd_symbol(segments,DIGIT3); break; // fill 1000s place
case 5 :if(flag2 == 1)
lcd_symbol(segments,DIGIT2); break; // fill 10000splace
case 6 :
if((flag == 1))
lcd_symbol((DOT |segments),DIGIT1); // fill 100000s place
lcd_symbol(segments,DIGIT1);
if(number <10)
flag2 = 0; // flag2 here is used to display 0.0. If we not used this data displayed is only 0 till it reaches to 10.
lcd_symbol(Digit_Map[i],DIGIT2);
flag2 = 1;
lcd_pos++;
#int_ccp1
void ccp1_isr(void)
// ccp1 interrupt is used to measure the count between two rising pulses. Here we
//are connected frequency generator to pin no 16 of 16f913
sec_counter++;
if(sec_counter >= 337)
flag =~flag; // compliment flag for decimal point.
sec_counter = 0;
min_count++;
{ // so number is incremented once after 3 sec.
number++;
number = 0;
min_count = 0;
//set_timer1(0);
#INT_TIMER0
sec_count++;
// Declaration of eeprom write here will take more time to increment the number.....
sec_count = 0;
init_CPU();
number = ee_read32(eeprom_address); //read data from EEPROM loc 0x00
printf(lcd_putc,"\f%6lu",number);
int32 ee_read32(int16 base_address)
int8 j;
int32 data_read;
for(j=0; j<4; j++)
*(&data_read+j) = read_eeprom(base_address+j);
return (data_read);
void ee_write32(int16 base_address ,int32 data)
int8 j;
for(j=0; j<4; j++)
write_eeprom(base_address+j,*(&data+j));
void init_CPU()
/************** PORT SETTINGS ****************/
PORT_B_PULLUPS(0XC0); // RB7 & RB6 i/p for programming devices.
SET_TRIS_A(0X80); //
SET_TRIS_B(0XC0);
SET_TRIS_C(0X27); //VLCD 1,2,3 i/p
SET_TRIS_E(0X08); // RE3 i/p for programming the device.
/*************** LCD SETTINGS ********************/
SETUP_LCD( LCD_MUX14 |LCD_INTRC|VLCD_ENABLE, 2);
/**************** COMPARATOR SETTINGS ***************/
SETUP_COMPARATOR(NC_NC_NC_NC);
/**************** INTERRUPT SETTINGS *****************/
ENABLE_INTERRUPTS(GLOBAL);
ENABLE_INTERRUPTS(INT_TIMER0); //enable timer1 interrupt
SET_TIMER0(61); // timer0 interrupt for 25 msec.
SETUP_TIMER_0(RTCC_INTERNAL|RTCC_DIV_256);
set_timer1(0);
setup_ccp1(CCP_CAPTURE_RE); //Capture on rising edge
clear_interrupt(INT_CCP1);
enable_interrupts(INT_CCP1);
setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);
_________________ Thank You,
With Best Regards,
Deepak. |
rnielsen
Posted: Thu Aug 30, 2007 8:26 am |
I only looked at your code quickly but I noticed one thing.
Code: | void ee_write32(int16 base_address ,int32 data)
int8 j;
for(j=0; j<4; j++)
This part only has 256 bytes of eeprom inside of it. You have declared your addressing as a 16 bit value. This can only be an 8 bit value. You can only write one byte at a time, also. You have declared this as a 32 bit value. Things aren't going to be compatible this way. When your address goes above 255 it will start over-writing the eeprom at address 0 again. Your 32 bit variable will only be saving the lowest 8 bits of data.
Ronald |
deepakomanna
Posted: Thu Aug 30, 2007 9:51 pm |
Thanks for notifieng this,
After this i have changed
int16 base_address to int8 base_address
And i want to store 32 bit data so i choosed
int32 data
still the problem is not solved.
any help appriciated _________________ Thank You,
With Best Regards,
Deepak. |
rnielsen
Posted: Fri Aug 31, 2007 8:51 am |
You will need to write one byte at a time. You could pass the 32bit variable to ee_write32() and then shift/mask the data, inside of the function, so you can save each 8bit portion of it. You will need to re-construct the variable when you read it from the eeprom.
Keep in mind that you will only have enough room to store 64 - 32bit variables this way since each one will take 4 bytes of space.
Ronald |
