Wireless Communication Problem
TheRidDler
PostPosted: Sun Jun 24, 2007 9:47 pm     Reply with quote
Hi all! I really love this forum, one learns quickly here Smile I have a small problem, i hope you can help me with this, as its my final year project and need to get this working or no degree :( Me and a friend wrote this code together specifically for our system.
This is our setup : We have a remote board with a GPS unit and a Radiometrix Transmitter. The board is controlled by a 18F252. The PIC takes the positional sentence from the GPS and transmits it to the local receiver board. The local board has a Radiometrix Receiver unit , 18F252 and a MAX232N. This board only relays the data to the PC so that a GUI can play with it.
When opening the console window however, absolutely nothing gets received. If possible could you guys that probably know a bit more about PIC coding than us please take a look at our code to see if you can maybe spot something that might be causing this? Thanks alot for all your help!
Remote (GPS) Board
#include <18F252.h>
#include <stdlib.h>
#fuses NOWDT,HS, NOPUT, NOPROTECT, NOBROWNOUT, NOLVP, NOCPD, NOWRT
#use rs232(baud=9600,stop=1,parity=N,rcv=PIN_B4,bits=8,stream=GPS,errors)              //data from GPS to PIC
char ToBeSend[128],EncodedData[256];
void encodeRF()
       //Encoding of data byte to manchester coding
       char Send1,Send2,txbyte;
       int8 encode=0, index=0;
       while (encode < 128){
       txbyte = ToBeSend[encode];
       encode++;
       if (bit_test(txbyte,7)) { bit_set(Send1,7), bit_clear(Send1,6); }
       else { bit_clear(Send1,7), bit_set(Send1,6); }
       if (bit_test(txbyte,6)) { bit_set(Send1,5), bit_clear(Send1,4); }
       else { bit_clear(Send1,5), bit_set(Send1,4); }
       if (bit_test(txbyte,5)) { bit_set(Send1,3), bit_clear(Send1,2); }
       else { bit_clear(Send1,3), bit_set(Send1,2); }
       if (bit_test(txbyte,4)) { bit_set(Send1,1), bit_clear(Send1,0); }
       else { bit_clear(Send1,1), bit_set(Send1,0); }
       if (bit_test(txbyte,3)) { bit_set(Send2,7), bit_clear(Send2,6); }
       else { bit_clear(Send2,7), bit_set(Send2,6); }
       if (bit_test(txbyte,2)) { bit_set(Send2,5), bit_clear(Send2,4); }
       else { bit_clear(Send2,5), bit_set(Send2,4); }
       if (bit_test(txbyte,1)) { bit_set(Send2,3), bit_clear(Send2,2); }
       else { bit_clear(Send2,3), bit_set(Send2,2); }
       if (bit_test(txbyte,0)) { bit_set(Send2,1), bit_clear(Send2,0); }
       else { bit_clear(Send2,1), bit_set(Send2,0); }
       EncodedData[index] = Send1;
       EncodedData[index+1] = Send2;
       index = index+2;
void Transmit(char IDUnit)
       int8 i = 0;
       set_tris_a(0x00);
       #use rs232(baud=57600,parity=N,bits=8,xmit=PIN_A0,RESTART_WDT,errors)// data from PIC to PC
       //delay_ms(40); //Give Relay Unit time to change TRX to RX mode
       delay_ms(5);
       for (i=0;i<200;i++) //Training sequence
         putc(0xAA);
       putc(0xFF);
       putc(0xFF);
       putc(0xCC);         //Header #1
       putc(0x33);         //Header #2
       putc(0x55);         //Header #3
       putc(IDUnit);       //ID of unit to be communicated to
       for (i=0; i<256; i++)//Data
         putc(EncodedData[i]);
       putc(0x00);         //Ending Sequence of transmition
       putc(0x00);
       for (i=0;i<128;i++)
      {           //clear the TX buffer for next transmission
         ToBeSend[i] = 0x00;
#define GPS_BUFFER_SIZE   128
char gps_buffer[GPS_BUFFER_SIZE];                                               // A place to store the string
char *GPS_GetField( int index )
   char *p = gps_buffer;
   int count = 0;
   while( *p )
      if( *p++ == ',' )
         if( count++ == index )
            return p;
   return p;
long GPS_Min_To_Dec( char *p )
   long value;
   int  decimal;
   value = atol(p) + 3;                                                     // to round to the nearest minute
   decimal = value % 100;
   value -= decimal;
   value /= 10;
   value += decimal / 6;
   return value;
void Send_To_PC()
   int t;
   for(t=0;t<GPS_BUFFER_SIZE;t++)
      ToBeSend[t]=gps_buffer[t];
   encodeRF();
   Transmit(0xAA);
   char ch;
   int checksum1, checksum2, index;
   set_tris_b( 0xFF );
   port_b_pullups( 1 );
   for(;;)
      ch = getch(GPS);
      switch( ch )
         case '\n':
         continue;
         case '$':
         index = checksum1 = checksum2 = 0;
         case '*':
         checksum2 = 1;
         case '\r':
            ch = gps_buffer[index-2];
            checksum2 = ((ch < 'A') ? (ch - '0') : (ch - 'A' + 10)) << 4;
            ch = gps_buffer[index-1];
            checksum2 += ((ch < 'A') ? (ch - '0') : (ch - 'A' + 10));
            if( checksum1 == checksum2  )
               gps_buffer[index] = 0;
               // the first unique letter is R
               if( gps_buffer[3] == 'R' )
                  Send_To_PC();
         default:
         if( checksum2 == 0 )
            checksum1 ^= ch;
      if( index < GPS_BUFFER_SIZE - 1 )
         gps_buffer[index++] = ch;
Local Reveiver Board
#include <18F252.h>
#include <stdlib.h>
const char Address = 0xAA;
char Received[256],RFIndicator = 0x00,DecodedData[128];
int16 timeout = 0;
char decodeRF (char P1,P2)
      char value = 0x00;
      //Decoding of manchester encoded received information
      disable_interrupts(GLOBAL);
      if( bit_test(P2,0) && !bit_test(P2,1) ) { bit_clear ( value,0); }
      else if( !bit_test(P2,0) &&  bit_test(P2,1) ) { bit_set ( value,0); }
      else goto ERROR;
      if(  bit_test(P2,2) && !bit_test(P2,3) ) { bit_clear ( value,1); }
      else if( !bit_test(P2,2) &&  bit_test(P2,3) ) { bit_set ( value,1); }
      else goto ERROR;
      if(  bit_test(P2,4) && !bit_test(P2,5) ) { bit_clear ( value,2); }
      else if( !bit_test(P2,4) &&  bit_test(P2,5) ) { bit_set ( value,2); }
      else goto ERROR;
      if(  bit_test(P2,6) && !bit_test(P2,7) ) { bit_clear ( value,3); }
      else if( !bit_test(P2,6) &&  bit_test(P2,7) ) { bit_set ( value,3); }
      else goto ERROR;
      if(  bit_test(P1,0) && !bit_test(P1,1) ) { bit_clear ( value,4); }
      else if( !bit_test(P1,0) &&  bit_test(P1,1) ) { bit_set ( value,4); }
      else goto ERROR;
      if(  bit_test(P1,2) && !bit_test(P1,3) ) { bit_clear ( value,5); }
      else if( !bit_test(P1,2) &&  bit_test(P1,3) ) { bit_set ( value,5); }
      else goto ERROR;
      if(  bit_test(P1,4) && !bit_test(P1,5) ) { bit_clear ( value,6); }
      else if( !bit_test(P1,4) &&  bit_test(P1,5) ) { bit_set ( value,6); }
      else goto ERROR;
      if(  bit_test(P1,6) && !bit_test(P1,7) ) { bit_clear ( value,7); }
      else if( !bit_test(P1,6) &&  bit_test(P1,7) ) { bit_set ( value,7); }
      else goto ERROR;
      // value decoded
      return value;
      ERROR:
      return 'E';
void Send_To_GUI()
   int t;
   #use rs232(baud=57600,stop=1,parity=N,xmit=PIN_A0,rcv=PIN_A1,bits=8,errors)
    output_high(PIN_B3);
   for(t=0;t<128;t++)
      putc(DecodedData[t]);
void Receive()
   int  counter = 0x00, position = 0x00;
   char Header[3] = {0x00,0x00,0x00};
   char Identifier = 0x00;
   int  RFtimeout = 20;
   for (counter=0;counter<128;counter++)
       Received[counter] = 0x00;
   counter = 0x00;
   #use rs232(baud=57600,stop=1,parity=N,rcv=PIN_C7,bits=8,RESTART_WDT,errors)
   //WAITING RX ROUTINE..
   set_timer3(0x0000);
   timeout = 0;
   enable_interrupts(int_TIMER3);
   enable_interrupts(global);
   WAIT:
         Header[0] = getchar();
         if(timeout > RFtimeout)
            disable_interrupts(int_TIMER3);
            timeout = 0;
            RFIndicator = 0x01; //This is the timeout and well received indicator
            goto OUT;
         if(Header[0] != 0xCC)
            goto WAIT;
         Header[1] = getchar();
            timeout = 0;
            goto OUT;
         if(Header[1] != 0x33)
            goto WAIT;
         Header[2] = getchar();
            timeout = 0;
            RFIndicator = 0x02; //This is the timeout and well received indicator
            goto OUT;
         if(Header[2]!= 0x55)
            goto WAIT;
         Identifier = getchar();
            timeout = 0;
            RFIndicator = 0x03; //This is the timeout and well received indicator
            goto OUT;
         if(Identifier != Address)
            goto WAIT;
         Identifier = 0x00;
         while(counter < 128)
                Received[counter] = getchar();
                counter++;
       counter = 0x00;
         while (counter < 64)
           DecodedData[position] = decodeRF(Received[counter],Received[counter+1]);
           position++;
           counter = counter + 2;
         RFIndicator = 0x00; //This is the timeout and well received indicator
         OUT:
            disable_interrupts(global);
   output_high(PIN_B2);
         Receive();
         Send_To_GUI();
         output_low(PIN_B3);
Some Additional Info :
Remote Board -> GPS Receive(Pin B4), RF Xmit(Pin A0) [GPS=9600,RF=57600]
Local Receiver Board -> RF Receive(Pin C7), Max232 Xmit(Pin A0),Max232 Rcv (Pin A1), B2&B3 - LED's [RF=57600, Max232=57600]
Both run at 20Mhz.
Thnx again! Embarassed
grasspuddle
PostPosted: Tue Jun 26, 2007 6:39 am     Reply with quote
Is your for loop suppose to be empty?
   char ch;
   set_tris_b( 0xFF );
  for(;;)
      ch = getch(GPS);
[/b]
TheRidDler
PostPosted: Tue Jun 26, 2007 8:42 am     Reply with quote
Hey, thnx for the reply. Yes, that part of the code is working fine, the problem lies somewhere in the RF section... Laughing
PostPosted: Tue Jun 26, 2007 1:16 pm     Reply with quote
You're enabling interrupts, but you don't have an #INT_TIMER3
interrupt service routine. This means your program will crash
the first time it gets a Timer3 interrupt.
set_tris_a(0x00);
You're setting the TRIS, but you haven't specified #use fast_io(a) mode.
The default mode of the compiler is "standard io" mode. In that mode
it sets the TRIS for you. Because the compiler is in standard i/o mode,
the library code and the CCS pin i/o functions will override your
set_tris_a(0x00) statement as required.
I didn't check the rest of your code because there's just too much of it.
