TheRidDler
Wireless Communication Problem |
Posted: Sun Jun 24, 2007 9:47 pm |
Hi all! I really love this forum, one learns quickly here I have a small problem, i hope you can help me with this, as its my final year project and need to get this working or no degree :( Me and a friend wrote this code together specifically for our system.
This is our setup : We have a remote board with a GPS unit and a Radiometrix Transmitter. The board is controlled by a 18F252. The PIC takes the positional sentence from the GPS and transmits it to the local receiver board. The local board has a Radiometrix Receiver unit , 18F252 and a MAX232N. This board only relays the data to the PC so that a GUI can play with it.
When opening the console window however, absolutely nothing gets received. If possible could you guys that probably know a bit more about PIC coding than us please take a look at our code to see if you can maybe spot something that might be causing this? Thanks alot for all your help!
Remote (GPS) Board
#include <18F252.h>
#include <stdlib.h>
#fuses NOWDT,HS, NOPUT, NOPROTECT, NOBROWNOUT, NOLVP, NOCPD, NOWRT
#use rs232(baud=9600,stop=1,parity=N,rcv=PIN_B4,bits=8,stream=GPS,errors) //data from GPS to PIC
char ToBeSend[128],EncodedData[256];
void encodeRF()
//Encoding of data byte to manchester coding
char Send1,Send2,txbyte;
int8 encode=0, index=0;
while (encode < 128){
txbyte = ToBeSend[encode];
encode++;
if (bit_test(txbyte,7)) { bit_set(Send1,7), bit_clear(Send1,6); }
else { bit_clear(Send1,7), bit_set(Send1,6); }
if (bit_test(txbyte,6)) { bit_set(Send1,5), bit_clear(Send1,4); }
else { bit_clear(Send1,5), bit_set(Send1,4); }
if (bit_test(txbyte,5)) { bit_set(Send1,3), bit_clear(Send1,2); }
else { bit_clear(Send1,3), bit_set(Send1,2); }
if (bit_test(txbyte,4)) { bit_set(Send1,1), bit_clear(Send1,0); }
else { bit_clear(Send1,1), bit_set(Send1,0); }
if (bit_test(txbyte,3)) { bit_set(Send2,7), bit_clear(Send2,6); }
else { bit_clear(Send2,7), bit_set(Send2,6); }
if (bit_test(txbyte,2)) { bit_set(Send2,5), bit_clear(Send2,4); }
else { bit_clear(Send2,5), bit_set(Send2,4); }
if (bit_test(txbyte,1)) { bit_set(Send2,3), bit_clear(Send2,2); }
else { bit_clear(Send2,3), bit_set(Send2,2); }
if (bit_test(txbyte,0)) { bit_set(Send2,1), bit_clear(Send2,0); }
else { bit_clear(Send2,1), bit_set(Send2,0); }
EncodedData[index] = Send1;
EncodedData[index+1] = Send2;
index = index+2;
void Transmit(char IDUnit)
int8 i = 0;
set_tris_a(0x00);
#use rs232(baud=57600,parity=N,bits=8,xmit=PIN_A0,RESTART_WDT,errors)// data from PIC to PC
//delay_ms(40); //Give Relay Unit time to change TRX to RX mode
delay_ms(5);
for (i=0;i<200;i++) //Training sequence
putc(0xAA);
putc(0xFF);
putc(0xFF);
putc(0xCC); //Header #1
putc(0x33); //Header #2
putc(0x55); //Header #3
putc(IDUnit); //ID of unit to be communicated to
for (i=0; i<256; i++)//Data
putc(EncodedData[i]);
putc(0x00); //Ending Sequence of transmition
putc(0x00);
for (i=0;i<128;i++)
{ //clear the TX buffer for next transmission
ToBeSend[i] = 0x00;
#define GPS_BUFFER_SIZE 128
char gps_buffer[GPS_BUFFER_SIZE]; // A place to store the string
char *GPS_GetField( int index )
char *p = gps_buffer;
int count = 0;
while( *p )
if( *p++ == ',' )
if( count++ == index )
return p;
return p;
long GPS_Min_To_Dec( char *p )
long value;
int decimal;
value = atol(p) + 3; // to round to the nearest minute
decimal = value % 100;
value -= decimal;
value /= 10;
value += decimal / 6;
return value;
void Send_To_PC()
int t;
for(t=0;t<GPS_BUFFER_SIZE;t++)
ToBeSend[t]=gps_buffer[t];
encodeRF();
Transmit(0xAA);
char ch;
int checksum1, checksum2, index;
set_tris_b( 0xFF );
port_b_pullups( 1 );
for(;;)
ch = getch(GPS);
switch( ch )
case '\n':
continue;
case '$':
index = checksum1 = checksum2 = 0;
case '*':
checksum2 = 1;
case '\r':
ch = gps_buffer[index-2];
checksum2 = ((ch < 'A') ? (ch - '0') : (ch - 'A' + 10)) << 4;
ch = gps_buffer[index-1];
checksum2 += ((ch < 'A') ? (ch - '0') : (ch - 'A' + 10));
if( checksum1 == checksum2 )
gps_buffer[index] = 0;
// the first unique letter is R
if( gps_buffer[3] == 'R' )
Send_To_PC();
default:
if( checksum2 == 0 )
checksum1 ^= ch;
if( index < GPS_BUFFER_SIZE - 1 )
gps_buffer[index++] = ch;
Local Reveiver Board
#include <18F252.h>
#include <stdlib.h>
const char Address = 0xAA;
char Received[256],RFIndicator = 0x00,DecodedData[128];
int16 timeout = 0;
char decodeRF (char P1,P2)
char value = 0x00;
//Decoding of manchester encoded received information
disable_interrupts(GLOBAL);
if( bit_test(P2,0) && !bit_test(P2,1) ) { bit_clear ( value,0); }
else if( !bit_test(P2,0) && bit_test(P2,1) ) { bit_set ( value,0); }
else goto ERROR;
if( bit_test(P2,2) && !bit_test(P2,3) ) { bit_clear ( value,1); }
else if( !bit_test(P2,2) && bit_test(P2,3) ) { bit_set ( value,1); }
else goto ERROR;
if( bit_test(P2,4) && !bit_test(P2,5) ) { bit_clear ( value,2); }
else if( !bit_test(P2,4) && bit_test(P2,5) ) { bit_set ( value,2); }
else goto ERROR;
if( bit_test(P2,6) && !bit_test(P2,7) ) { bit_clear ( value,3); }
else if( !bit_test(P2,6) && bit_test(P2,7) ) { bit_set ( value,3); }
else goto ERROR;
if( bit_test(P1,0) && !bit_test(P1,1) ) { bit_clear ( value,4); }
else if( !bit_test(P1,0) && bit_test(P1,1) ) { bit_set ( value,4); }
else goto ERROR;
if( bit_test(P1,2) && !bit_test(P1,3) ) { bit_clear ( value,5); }
else if( !bit_test(P1,2) && bit_test(P1,3) ) { bit_set ( value,5); }
else goto ERROR;
if( bit_test(P1,4) && !bit_test(P1,5) ) { bit_clear ( value,6); }
else if( !bit_test(P1,4) && bit_test(P1,5) ) { bit_set ( value,6); }
else goto ERROR;
if( bit_test(P1,6) && !bit_test(P1,7) ) { bit_clear ( value,7); }
else if( !bit_test(P1,6) && bit_test(P1,7) ) { bit_set ( value,7); }
else goto ERROR;
// value decoded
return value;
ERROR:
return 'E';
void Send_To_GUI()
int t;
#use rs232(baud=57600,stop=1,parity=N,xmit=PIN_A0,rcv=PIN_A1,bits=8,errors)
output_high(PIN_B3);
for(t=0;t<128;t++)
putc(DecodedData[t]);
void Receive()
int counter = 0x00, position = 0x00;
char Header[3] = {0x00,0x00,0x00};
char Identifier = 0x00;
int RFtimeout = 20;
for (counter=0;counter<128;counter++)
Received[counter] = 0x00;
counter = 0x00;
#use rs232(baud=57600,stop=1,parity=N,rcv=PIN_C7,bits=8,RESTART_WDT,errors)
//WAITING RX ROUTINE..
set_timer3(0x0000);
timeout = 0;
enable_interrupts(int_TIMER3);
enable_interrupts(global);
WAIT:
Header[0] = getchar();
if(timeout > RFtimeout)
disable_interrupts(int_TIMER3);
timeout = 0;
RFIndicator = 0x01; //This is the timeout and well received indicator
goto OUT;
if(Header[0] != 0xCC)
goto WAIT;
Header[1] = getchar();
timeout = 0;
goto OUT;
if(Header[1] != 0x33)
goto WAIT;
Header[2] = getchar();
timeout = 0;
RFIndicator = 0x02; //This is the timeout and well received indicator
goto OUT;
if(Header[2]!= 0x55)
goto WAIT;
Identifier = getchar();
timeout = 0;
RFIndicator = 0x03; //This is the timeout and well received indicator
goto OUT;
if(Identifier != Address)
goto WAIT;
Identifier = 0x00;
while(counter < 128)
Received[counter] = getchar();
counter++;
counter = 0x00;
while (counter < 64)
DecodedData[position] = decodeRF(Received[counter],Received[counter+1]);
position++;
counter = counter + 2;
RFIndicator = 0x00; //This is the timeout and well received indicator
OUT:
disable_interrupts(global);
output_high(PIN_B2);
Receive();
Send_To_GUI();
output_low(PIN_B3);
Some Additional Info :
Remote Board -> GPS Receive(Pin B4), RF Xmit(Pin A0) [GPS=9600,RF=57600]
Local Receiver Board -> RF Receive(Pin C7), Max232 Xmit(Pin A0),Max232 Rcv (Pin A1), B2&B3 - LED's [RF=57600, Max232=57600]
Both run at 20Mhz.
Thnx again! |
grasspuddle
Posted: Tue Jun 26, 2007 6:39 am |
Is your for loop suppose to be empty?
Quote: | Code: |
char ch;
set_tris_b( 0xFF );
for(;;)
ch = getch(GPS);
| [/b] |
TheRidDler
Posted: Tue Jun 26, 2007 8:42 am |
Hey, thnx for the reply. Yes, that part of the code is working fine, the problem lies somewhere in the RF section... |
Posted: Tue Jun 26, 2007 1:16 pm |
Quote: | enable_interrupts(int_TIMER3);
enable_interrupts(global); |
You're enabling interrupts, but you don't have an #INT_TIMER3
interrupt service routine. This means your program will crash
the first time it gets a Timer3 interrupt.
You're setting the TRIS, but you haven't specified #use fast_io(a) mode.
The default mode of the compiler is "standard io" mode. In that mode
it sets the TRIS for you. Because the compiler is in standard i/o mode,
the library code and the CCS pin i/o functions will override your
set_tris_a(0x00) statement as required.
I didn't check the rest of your code because there's just too much of it. |
