16F628A and SETUP_ADC_PORTS(NO_ANALOGS)
Manah
PostPosted: Fri Jun 15, 2007 11:07 pm     Reply with quote
Hello.
#include <16F628A.h>
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOPUT                    //No Power Up Timer
char ch[20];
int dat;
   output_high(PIN_B7);
   output_low(PIN_B4);
  SETUP_ADC_PORTS(NO_ANALOGS);
         #use rs232(baud=9600,parity=N,xmit=PIN_A2,rcv=PIN_A3,bits=8)
         while (getc() != 'A');
            dat = getc();
         #use rs232(baud=9600,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8)
         putc(dat);
Compiler: Undefined identifier SETUP_ADC_PORTS
What is wrong?
PostPosted: Sat Jun 16, 2007 2:09 am     Reply with quote
Download the data sheet for the 16F628A. Look at the features list
on the front page. Does it show an A/D module ?
http://ww1.microchip.com/downloads/en/DeviceDoc/40044F.pdf
