Manah Guest
| 16F628A and SETUP_ADC_PORTS(NO_ANALOGS) |
Posted: Fri Jun 15, 2007 11:07 pm |
Hello.
#include <16F628A.h>
#FUSES HS //High speed Osc (> 4mhz)
char ch[20];
int dat;
output_high(PIN_B7);
output_low(PIN_B4);
SETUP_ADC_PORTS(NO_ANALOGS);
#use rs232(baud=9600,parity=N,xmit=PIN_A2,rcv=PIN_A3,bits=8)
while (getc() != 'A');
dat = getc();
#use rs232(baud=9600,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8)
putc(dat);
Compiler: Undefined identifier SETUP_ADC_PORTS
What is wrong? |
