Determining bitsize
aodj
Determining bitsize
PostPosted: Fri Apr 27, 2007 2:00 am     Reply with quote
Is there any way to determine the size, or width, of a variable at runtime?
For example, [in psuedo]
if(a.bitsize == 8)
Thus running one statement if it was 16 bits, and another if it was 8.
Pret
PostPosted: Fri Apr 27, 2007 2:26 am     Reply with quote
You meen sizeof ?!
case(sizeof(a))
switch 1: /* handle 8bit */ break;
switch 2: /* handle 16bit */ break;
switch 4: /* handle 32bit*/ break;
I hope that's what you want...
aodj
PostPosted: Fri Apr 27, 2007 3:51 am     Reply with quote
Ok, thanks, that was exactly what I was looking for.
In addition to the above, is there anyway to pass a variable sized value to a subroutine? For example, normally a subroutine is declared as:
void fIncrement(int8 v1)
This obviously limits the values passed to the routine to being int8's. Is there another way to express this so that v1 can be either 8 bit -or- 16?
Edit: Or would overloading the function be the only way to handle different data types?
Pret
PostPosted: Fri Apr 27, 2007 7:26 am     Reply with quote
You cand always pass a pointer to function... using void* as type, bust still you'll have to pass the size as another parameter.
Best thing to do is to define a type. Ex:
typedef int8 integer;
integer a;
void fIncrement(integer a)
   int8 x;
// you can do any integer operation
   a++;
   x = a;
   a|=4;
// and so on
if you want to send it, you can do:
int8 *ptr;
int8 i;
ptr = &a;
for(i=0; i<sizeof(a); i++)
   putc(ptr[i]);
if you want to use printf...
if(sizeof(a) == 1) printf("a=%u", a); // for 8 bit
   else printf("a=%lu", a); // for 16 and 32 bit
if you want to change the type for integer, only needed thing to do is to change the basic type from typedef declaration to int16 or int32
Note that this is a compile time operation. Cannot be changed in runtime.
Foppie
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Fri Apr 27, 2007 7:48 am     Reply with quote
aodj wrote:
Is there anyway to pass a variable sized value to a subroutine? For example, normally a subroutine is declared as:
if you make it
void fIncrement(int16 v1)
you can send both int8 as int16 to the function, if you send an int8, the compiler will make a cast to a int16.
hope this helps...
