aodj
Determining bitsize |
Posted: Fri Apr 27, 2007 2:00 am |
Is there any way to determine the size, or width, of a variable at runtime?
For example, [in psuedo]
Code: | if(a.bitsize == 8)
Thus running one statement if it was 16 bits, and another if it was 8. |
Pret
Joined: 18 Jul 2006 Posts: 92 Location: Iasi, Romania
Posted: Fri Apr 27, 2007 2:26 am |
You meen sizeof ?!
case(sizeof(a))
switch 1: /* handle 8bit */ break;
switch 2: /* handle 16bit */ break;
switch 4: /* handle 32bit*/ break;
I hope that's what you want... |
aodj
Posted: Fri Apr 27, 2007 3:51 am |
Ok, thanks, that was exactly what I was looking for.
In addition to the above, is there anyway to pass a variable sized value to a subroutine? For example, normally a subroutine is declared as:
Code: | void fIncrement(int8 v1)
This obviously limits the values passed to the routine to being int8's. Is there another way to express this so that v1 can be either 8 bit -or- 16?
Edit: Or would overloading the function be the only way to handle different data types? |
Pret
Posted: Fri Apr 27, 2007 7:26 am |
You cand always pass a pointer to function... using void* as type, bust still you'll have to pass the size as another parameter.
Best thing to do is to define a type. Ex:
Code: | typedef int8 integer;
integer a;
void fIncrement(integer a)
int8 x;
// you can do any integer operation
a++;
x = a;
a|=4;
// and so on
if you want to send it, you can do:
Code: | int8 *ptr;
int8 i;
ptr = &a;
for(i=0; i<sizeof(a); i++)
putc(ptr[i]);
if you want to use printf...
Code: | if(sizeof(a) == 1) printf("a=%u", a); // for 8 bit
else printf("a=%lu", a); // for 16 and 32 bit
if you want to change the type for integer, only needed thing to do is to change the basic type from typedef declaration to int16 or int32
Note that this is a compile time operation. Cannot be changed in runtime. |
Foppie
Joined: 16 Sep 2005 Posts: 138 Location: The Netherlands
Posted: Fri Apr 27, 2007 7:48 am |
aodj wrote: | Is there anyway to pass a variable sized value to a subroutine? For example, normally a subroutine is declared as:
This obviously limits the values passed to the routine to being int8's. Is there another way to express this so that v1 can be either 8 bit -or- 16? |
if you make it Code: | void fIncrement(int16 v1)
} | you can send both int8 as int16 to the function, if you send an int8, the compiler will make a cast to a int16.
hope this helps... |
