vin883 Guest
compilation problem |
Posted: Fri Apr 06, 2007 7:39 am |
Hi all,
I just have installed PCH 4.031 and since then I can't compile my old projects anymore using PCM 3.249.
I'm also using Mplab IDE v7.00, my OS is windows 2000. |
Posted: Fri Apr 06, 2007 8:38 am |
To use multiple compilers, involves several 'steps'.
The first, is that you _must_ change the default directory name, where the compiler is installed. By default, all versions will install in 'Program Files/PICC', and will overwrite existing versions, unless this is changed.
Then, in MPLab, for a given project, you need to change the 'language tool locations', to point to the compiler you want this project to use.
Posted: Fri Apr 06, 2007 9:10 am |
That solved my problem, thanks for your great help ![Surprised](images/smiles/icon_surprised.gif) |
