printf("OK");
LIAN
printf("OK");
PostPosted: Fri Apr 06, 2007 2:26 am     Reply with quote
printf(lcd_putc, "OK")---we can see "OK" in LCD
printf("OK");------where can we see "OK"?
libor
PostPosted: Fri Apr 06, 2007 3:04 am     Reply with quote
on the serial port, that you have initialized with #use rs232... command previously.
LIAN
but still
PostPosted: Fri Apr 06, 2007 3:17 am     Reply with quote
I have done printf("OK"); but I have gotten <-Åþ>
but not <OK>. I use <Free>, is there sth to configure?
PostPosted: Fri Apr 06, 2007 7:14 am     Reply with quote
The #use delay line, must match the clock source being used by the processor, and the right hardware connections (level translators/inverters) are needed.
noname
PostPosted: Sat Apr 07, 2007 2:59 am     Reply with quote
Also make sure you have the correct baudrate.
rnielsen
PostPosted: Mon Apr 09, 2007 8:39 am     Reply with quote
Make sure the 'bits' in the #use rs232() is set to the same as your terminal program. This has bit me a few times (no pun intended) when the wizzard stuck bits=9 in it when I actually use 8 bits in my terminal setup.
Ronald
LIAN
thank you for your replay
PostPosted: Mon Apr 09, 2007 2:14 pm     Reply with quote
thank you, i will try it and then tell your the result
Humberto
PostPosted: Mon Apr 09, 2007 6:01 pm     Reply with quote
Just to remember an old tibetano saying:
"When everything else fails and nothing work: read the instructions" Cool
http://www.ccsinfo.com/faq.php?page=rs232_errors
Humberto
