funmix
I2C not working in 18F4520[error] |
Posted: Wed Apr 04, 2007 6:45 am |
The below program work fine for 18F4520 master with 16F877A slave.
When i replace 16F877A with 18F4520 as slave, i got the i2c_read() value display in hyperterminal is FFFF, no matter what value i enter, master display FFFF.
p/s: I have re-configure those special function register value for different chips
Appreciate if someone can help to solve this.
This code is taken from code library i2c master and slave multibyte
//master.c
#include <18F4520.H>
// 10-bit A/D conversion
#device ADC=10
#use Delay(Clock=20000000)
#use rs232(baud=19200,xmit=PIN_C6,rcv=PIN_C7,brgh1ok)
#include <input.c>
#define EEPROM_SDA PIN_C4
#define EEPROM_SCL PIN_C3
#define SLAVE_ADDRESS 0x02
#use i2c(master, sda=EEPROM_SDA, scl=EEPROM_SCL, FORCE_HW)
void
initI2C()
output_float(EEPROM_SCL);
output_float(EEPROM_SDA);
void
writeI2C(INT16 word)
i2c_start();
delay_us(16);
i2c_write(SLAVE_ADDRESS); /* Device Address */
delay_us(16);
i2c_write(word & 0x00ff);
delay_us(16);
i2c_write((word & 0xff00) >> 8);
delay_us(16);
i2c_stop();
INT16
readI2C()
BYTE b1=0, b2=0;
i2c_start(); // restart condition
i2c_write(SLAVE_ADDRESS + 1);
b1 = i2c_read(1);
delay_us(16);
b2 = i2c_read(0);
delay_us(16);
i2c_stop();
return make16(b2, b1);
INT16 gethexword() {
BYTE lo,hi;
hi = gethex();
lo = gethex();
return make16( hi,lo );
void main() {
int cmd;
INT16 value;
initI2C();
printf("i2c master 01 APRIL 2007\n\r\n\r");
do {
do
printf("\r\n[R]ead or [W]rite: ");
cmd=getc();
cmd=toupper(cmd);
putc(cmd);
if(cmd!='R' && (cmd!='W'))
value =0;
printf("\r\nStupid ah! Please retype!!");
} while ( (cmd!='R') && (cmd!='W') );
if(cmd=='R')
value = 0;
value = readI2C();
printf("\r\nValue: %lX\r\n",value );
} else if(cmd=='W')
printf("\r\nNew 16-bit value: ");//2 bytes
value = gethexword();
printf("\n\r");
writeI2C(value);
} while (TRUE);
slave
#include <16F877A.H>
#device ADC=10
unsigned char read_i2c(void);
void i2c_interrupt_handler(void);
void i2c_initialize(void);
void i2c_error(void);
void write_i2c(unsigned char transmit_byte);
#INT_SSP
void ssp_interupt ()
i2c_interrupt_handler();
/* 16f87X bytes */
/* Change it per chip */
#byte PIC_SSPBUF=0x13
#byte PIC_SSPADD=0x93
#byte PIC_SSPSTAT=0x94
#byte PIC_SSPCON1=0x14
#byte PIC_SSPCON2=0x91
/* Bit defines */
#define PIC_SSPSTAT_BIT_SMP 0x80
#define PIC_SSPSTAT_BIT_CKE 0x40
#define PIC_SSPSTAT_BIT_DA 0x20
#define PIC_SSPSTAT_BIT_P 0x10
#define PIC_SSPSTAT_BIT_S 0x08
#define PIC_SSPSTAT_BIT_RW 0x04
#define PIC_SSPSTAT_BIT_UA 0x02
#define PIC_SSPSTAT_BIT_BF 0x01
#define PIC_SSPCON1_BIT_WCOL 0x80
#define PIC_SSPCON1_BIT_SSPOV 0x40
#define PIC_SSPCON1_BIT_SSPEN 0x20
#define PIC_SSPCON1_BIT_CKP 0x10
#define PIC_SSPCON1_BIT_SSPM3 0x08
#define PIC_SSPCON1_BIT_SSPM2 0x04
#define PIC_SSPCON1_BIT_SSPM1 0x02
#define PIC_SSPCON1_BIT_SSPM0 0x01
#define PIC_SSPCON2_BIT_GCEN 0x80
#define PIC_SSPCON2_BIT_ACKSTAT 0x40
#define PIC_SSPCON2_BIT_ACKDT 0x20
#define PIC_SSPCON2_BIT_ACKEN 0x10
#define PIC_SSPCON2_BIT_RCEN 0x08
#define PIC_SSPCON2_BIT_PEN 0x04
#define PIC_SSPCON2_BIT_RSEN 0x02
#define PIC_SSPCON2_BIT_SEN 0x01
#define RX_BUF_LEN 32
#define NODE_ADDR 0x02 /* I2C address of the slave node */
unsigned char slave_buffer[RX_BUF_LEN];
int buffer_index;
int comms_error;
int debug_state;
/* Set up SSP module for 7-bit */
PIC_SSPCON1 = 0x36; /* 0011 0110 */
PIC_SSPADD = NODE_ADDR; /* Set the slave's address */
PIC_SSPSTAT = 0x00; /* Clear the SSPSTAT register. */
enable_interrupts(INT_SSP); /* Enable MSSP interrupts. */
unsigned char i2c_mask = 0x2D; /* 0010 1101 */
unsigned char temp_sspstat;
unsigned char this_byte;
unsigned char tx_byte;
int x;
/* Mask out the unnecessary bits */
temp_sspstat = PIC_SSPSTAT & i2c_mask;
switch (temp_sspstat)
/* Write operation, last byte was an address, buffer is full */
case 0x09: /* 0000 1001 */
/* Clear the receive buffer */
for (x=0; x<RX_BUF_LEN; x++)
slave_buffer[x] = 0x00;
buffer_index = 0; /* Clear the buffer index */
this_byte = read_i2c(); /* Do a dummy read of PIC_SSPBUF */
debug_state = 1;
/* Write operation, last byte was data, buffer is full */
case 0x29: /* 0010 1001 */
/* Point to the buffer */
this_byte = read_i2c(); /* Get the byte from the SSP */
slave_buffer[buffer_index] = this_byte; /* Put it into the buffer */
buffer_index++; /* Increment the buffer pointer */
/* Get the current buffer index */
/* Subtract the buffer length */
/* Has the index exceeded the buffer length? */
if (buffer_index >= RX_BUF_LEN)
buffer_index = 0; /* Yes, clear the buffer index. */
debug_state = 2;
/* Read operation; last byte was an address, buffer is empty */
case 0x0C: /* 0000 1100 */
tx_byte = slave_buffer[buffer_index]; /* Get byte from the buffer */
write_i2c(tx_byte); /* Write the byte to PIC_SSPBUF */
buffer_index++; /* increment the buffer index */
debug_state = 3;
/* Read operation; last byte was data, buffer is empty */
case 0x2C: /* 0010 1100 */
buffer_index = 0; /* Yes, clear the buffer index */
/* Get the byte */
write_i2c(tx_byte); /* Write to PIC_SSPBUF */
debug_state = 4;
/* A NACK was received when transmitting data back from the master. */
/* Slave logic is reset in this case. R_W=0, D_A=1, and BF=0. */
/* If we don't stop in this state, then something is wrong!! */
case 0x28: /* 0010 1000 */
debug_state = 5;
/* Something went wrong!! */
default:
i2c_error();
comms_error = 1;
printf ("I2C ERROR!\r\n");
unsigned char write_collision = 1;
while (PIC_SSPSTAT & PIC_SSPSTAT_BIT_BF) /* Is BF bit set in PIC_SSPSTAT? */
/* If yes, then keep waiting */
while (write_collision)
/* If not, then do the i2c_write. */
PIC_SSPCON1 &= ~PIC_SSPCON1_BIT_WCOL; /* Clear the WCOL flag */
PIC_SSPBUF = transmit_byte;
/* Was there a write collision? */
if (PIC_SSPCON1 & PIC_SSPCON1_BIT_WCOL)
/* Yes there was a write collision. */
/* NO, there was no write collision. */
/* The transmission was successful */
write_collision = 0;
PIC_SSPCON1 |= PIC_SSPCON1_BIT_CKP; /* Release the clock. */
/* This function returns the byte in SSPBUF */
return PIC_SSPBUF;
debug_state = 0;
i2c_initialize();
printf("i2c slave 01 APRIL 2007\n\r\n\r");
while (1)
if (debug_state)
printf ("debug state = %d\r\n", debug_state);
debug_state = 0;
Posted: Wed Apr 04, 2007 11:20 am |
Quote: | p/s: I have re-configure those special function register value for different chips |
Post those statements so we can see if they are correct. |
funmix
Posted: Wed Apr 04, 2007 5:30 pm |
#byte PIC_SSPBUF=0xfc9
#byte PIC_SSPADD=0xfc8
#byte PIC_SSPSTAT=0xfc7
#byte PIC_SSPCON1=0xfc6
#byte PIC_SSPCON2=0xfc5
I used 4.7k pullup register for I2C bus. Crystal running at 20Mhz. |
tom_hanks
Posted: Tue Apr 24, 2007 4:02 am |
i guess you need to do following change...
and may be you need to remove a while loop of BF in write_I2C...
if(PIC_SSPSTAT & PIC_SSPSTAT_BIT_BF)
PIC_PIR1 = 0x47 & PIC_PIR1;
return PIC_SSPBUF;
