		| View previous topic :: View next topic   |
			funmix
				| I2C not working in 18F4520[error] |
				 Posted: Wed Apr 04, 2007 6:45 am     |
				The below program work fine for 18F4520 master with 16F877A slave.
When i replace 16F877A with 18F4520 as slave, i got the i2c_read() value display in hyperterminal is FFFF, no matter what value i enter, master display FFFF.
p/s: I have re-configure those special function register value for different chips
Appreciate if someone can help to solve this.
This code is taken from code library i2c master and slave multibyte
//master.c
#include <18F4520.H>
// 10-bit A/D conversion
#device ADC=10
#use Delay(Clock=20000000)
#use rs232(baud=19200,xmit=PIN_C6,rcv=PIN_C7,brgh1ok)
#include <input.c>
#define EEPROM_SDA  PIN_C4
#define EEPROM_SCL  PIN_C3
#define SLAVE_ADDRESS 0x02
#use i2c(master, sda=EEPROM_SDA, scl=EEPROM_SCL, FORCE_HW)
void
initI2C()
 output_float(EEPROM_SCL);
 output_float(EEPROM_SDA);
void
writeI2C(INT16 word)
 i2c_start();
 delay_us(16);
 i2c_write(SLAVE_ADDRESS);  /* Device Address */
 delay_us(16);
 i2c_write(word & 0x00ff);
 delay_us(16);
 i2c_write((word & 0xff00) >> 8);
 delay_us(16);
 i2c_stop();
INT16
readI2C()
 BYTE b1=0, b2=0;
 i2c_start();   // restart condition
 i2c_write(SLAVE_ADDRESS + 1);
 b1 = i2c_read(1);
 delay_us(16);
 b2 = i2c_read(0);
 delay_us(16);
 i2c_stop();
 return make16(b2, b1);
INT16 gethexword() {
 BYTE lo,hi;
 hi = gethex();
 lo = gethex();
 return make16( hi,lo );
void main() {
 int cmd;
 INT16 value;
 initI2C();
 printf("i2c master 01 APRIL 2007\n\r\n\r");
 do {
    do
       printf("\r\n[R]ead or [W]rite: ");
       cmd=getc();
       cmd=toupper(cmd);
       putc(cmd);
       if(cmd!='R' && (cmd!='W'))
    value =0;
    printf("\r\nStupid ah! Please retype!!");
    } while ( (cmd!='R') && (cmd!='W') );
   if(cmd=='R')
      value = 0;
      value = readI2C();
      printf("\r\nValue: %lX\r\n",value );
   } else if(cmd=='W')
       printf("\r\nNew 16-bit value: ");//2 bytes
       value = gethexword();
       printf("\n\r");
       writeI2C(value);
 } while (TRUE);
slave
#include <16F877A.H>
#device ADC=10
unsigned char read_i2c(void);
void i2c_interrupt_handler(void);
void i2c_initialize(void);
void i2c_error(void);
void write_i2c(unsigned char transmit_byte);
#INT_SSP
void ssp_interupt ()
  i2c_interrupt_handler();
/* 16f87X bytes */
/* Change it per chip */
#byte PIC_SSPBUF=0x13
#byte PIC_SSPADD=0x93
#byte PIC_SSPSTAT=0x94
#byte PIC_SSPCON1=0x14
#byte PIC_SSPCON2=0x91
/* Bit defines */
#define PIC_SSPSTAT_BIT_SMP     0x80
#define PIC_SSPSTAT_BIT_CKE     0x40
#define PIC_SSPSTAT_BIT_DA      0x20
#define PIC_SSPSTAT_BIT_P       0x10
#define PIC_SSPSTAT_BIT_S       0x08
#define PIC_SSPSTAT_BIT_RW      0x04
#define PIC_SSPSTAT_BIT_UA      0x02
#define PIC_SSPSTAT_BIT_BF      0x01
#define PIC_SSPCON1_BIT_WCOL    0x80
#define PIC_SSPCON1_BIT_SSPOV   0x40
#define PIC_SSPCON1_BIT_SSPEN   0x20
#define PIC_SSPCON1_BIT_CKP     0x10
#define PIC_SSPCON1_BIT_SSPM3   0x08
#define PIC_SSPCON1_BIT_SSPM2   0x04
#define PIC_SSPCON1_BIT_SSPM1   0x02
#define PIC_SSPCON1_BIT_SSPM0   0x01
#define PIC_SSPCON2_BIT_GCEN    0x80
#define PIC_SSPCON2_BIT_ACKSTAT 0x40
#define PIC_SSPCON2_BIT_ACKDT   0x20
#define PIC_SSPCON2_BIT_ACKEN   0x10
#define PIC_SSPCON2_BIT_RCEN    0x08
#define PIC_SSPCON2_BIT_PEN     0x04
#define PIC_SSPCON2_BIT_RSEN    0x02
#define PIC_SSPCON2_BIT_SEN     0x01
#define RX_BUF_LEN  32
#define NODE_ADDR   0x02    /* I2C address of the slave node */
unsigned char slave_buffer[RX_BUF_LEN];
int buffer_index;
int comms_error;
int debug_state;
 /* Set up SSP module for 7-bit */
 PIC_SSPCON1 = 0x36;   /* 0011 0110 */
 PIC_SSPADD = NODE_ADDR;  /* Set the slave's address */
 PIC_SSPSTAT = 0x00;     /* Clear the SSPSTAT register. */
 enable_interrupts(INT_SSP);  /* Enable MSSP interrupts. */
  unsigned char i2c_mask = 0x2D;  /* 0010 1101 */
  unsigned char temp_sspstat;
  unsigned char this_byte;
  unsigned char tx_byte;
  int x;
  /* Mask out the unnecessary bits */
  temp_sspstat = PIC_SSPSTAT & i2c_mask;
  switch (temp_sspstat)
      /* Write operation, last byte was an address, buffer is full */
      case 0x09:   /* 0000 1001 */
          /* Clear the receive buffer */
          for (x=0; x<RX_BUF_LEN; x++)
             slave_buffer[x] = 0x00;
          buffer_index = 0;  /* Clear the buffer index */
          this_byte = read_i2c();   /* Do a dummy read of PIC_SSPBUF */
          debug_state = 1;
      /* Write operation, last byte was data, buffer is full */
      case 0x29:   /* 0010 1001 */
          /* Point to the buffer */
          this_byte = read_i2c();  /* Get the byte from the SSP */
          slave_buffer[buffer_index] = this_byte; /* Put it into the buffer */
          buffer_index++; /* Increment the buffer pointer */
          /* Get the current buffer index */
          /* Subtract the buffer length */
          /* Has the index exceeded the buffer length? */
          if (buffer_index >= RX_BUF_LEN)
             buffer_index = 0; /* Yes, clear the buffer index. */
          debug_state = 2;
      /* Read operation; last byte was an address, buffer is empty */
      case 0x0C:   /* 0000 1100 */
          tx_byte = slave_buffer[buffer_index]; /* Get byte from the buffer */
          write_i2c(tx_byte); /* Write the byte to PIC_SSPBUF */
          buffer_index++; /* increment the buffer index */
          debug_state = 3;
      /* Read operation; last byte was data, buffer is empty */
      case 0x2C:   /* 0010 1100 */
              buffer_index = 0; /* Yes, clear the buffer index */
          /* Get the byte */
          write_i2c(tx_byte);  /* Write to PIC_SSPBUF */
          debug_state = 4;
      /* A NACK was received when transmitting data back from the master. */
      /* Slave logic is reset in this case. R_W=0, D_A=1, and BF=0. */
      /* If we don't stop in this state, then something is wrong!! */
      case 0x28:   /* 0010 1000 */
          debug_state = 5;
      /* Something went wrong!! */
      default:
          i2c_error();
  comms_error = 1;
  printf ("I2C ERROR!\r\n");
  unsigned char write_collision = 1;
  while (PIC_SSPSTAT & PIC_SSPSTAT_BIT_BF) /* Is BF bit set in PIC_SSPSTAT? */
      /* If yes, then keep waiting */
  while (write_collision)
      /* If not, then do the i2c_write. */
      PIC_SSPCON1 &= ~PIC_SSPCON1_BIT_WCOL;  /* Clear the WCOL flag */
      PIC_SSPBUF = transmit_byte;
      /* Was there a write collision? */
      if (PIC_SSPCON1 & PIC_SSPCON1_BIT_WCOL)
          /* Yes there was a write collision. */
          /* NO, there was no write collision. */
          /* The transmission was successful */
          write_collision = 0;
  PIC_SSPCON1 |= PIC_SSPCON1_BIT_CKP;  /* Release the clock. */
/* This function returns the byte in SSPBUF */
  return PIC_SSPBUF;
  debug_state = 0;
  i2c_initialize();
 printf("i2c slave 01 APRIL 2007\n\r\n\r");
  while (1)
      if (debug_state)
           printf ("debug state = %d\r\n", debug_state);
          debug_state = 0;
				 Posted: Wed Apr 04, 2007 11:20 am     |
				 	  | Quote: | 	 		  | p/s: I have re-configure those special function register value for different chips  |
Post those statements so we can see if they are correct. |
			funmix
				 Posted: Wed Apr 04, 2007 5:30 pm     |
#byte PIC_SSPBUF=0xfc9
#byte PIC_SSPADD=0xfc8
#byte PIC_SSPSTAT=0xfc7
#byte PIC_SSPCON1=0xfc6
#byte PIC_SSPCON2=0xfc5
I used 4.7k pullup register for I2C bus. Crystal running at 20Mhz. |
			tom_hanks
				 Posted: Tue Apr 24, 2007 4:02 am     |
				i guess you need to do following change...
and may be you need to remove a while loop of BF in write_I2C...
  if(PIC_SSPSTAT & PIC_SSPSTAT_BIT_BF)
      PIC_PIR1  = 0x47 & PIC_PIR1;
      return PIC_SSPBUF;
