meepa123
Function behaves differently... possible bug? ccs 4.023 |
Posted: Mon Mar 19, 2007 5:49 am |
Hello
I have a function that plots points at a graphical LCD 128x64. The interface is OK.
b=20;
a=10;
glcd_pixel(a,b,ON);
glcd_pixel(a*2,b*2,ON);
glcd_pixel(a*3,b*3,ON);
glcd_pixel(a+1,b-1,ON);
glcd_pixel(a-1,b+1,ON);
Only the first THREE pixels are set at the lcd. The last two don't appear. I have the same problem, if i do this:
a=10;
for(b=1;b<=20;b++)
glcd_pixel(a,b,ON);
At this case, nothing is at the screen, where a line should appear.
I can't imagine it is a problem of the glcd managing routine, but at least i put the glcd_pixel routine, which may be the conflictive one.
void glcd_pixel(int8 x, int8 y, int1 color)
int8* p;
int16 temp;
temp = y/8;
temp *= 64;
temp += x;
if(x > 63)
p = displayData.right + temp - 64;
p = displayData.left + temp;
if(color)
bit_set(*p, y%8);
bit_clear(*p, y%8);
Where displayData.left and displayData.right are two 512byte arrays. Writing directly at those arrays, and then updating the LCD screen, results in correct data, so LCD fault should be discarded.
I hope you can help me!
PD: This is shocking...
a=10;
do
a++;
glcd_pixel(a,b,ON);
}while(a<=30);
This piece of code does work... and it equals to a for(a=10;a<=30;++a), doesn't it? The for does not work... |
KaraMuraT
Joined: 16 May 2006 Posts: 65 Location: Ankara/Turkey
Re: Function behaves differently... possible bug? ccs 4.023 |
Posted: Mon Mar 19, 2007 6:28 am |
I think your problem is at this lines:
Code: | int16 temp;
temp = y/8;
temp *= 64;
temp = y/8 and than temp *= 64 is very bad way. First of all you're wasting a division cyle which is the longest math operation.
Also Your code is equal to temp = y * 8 but with a difference. Your implementation truncates some values. Because temp is not a float. Therefore adding or subtracting values which are smaller than 8 generates same values. You should use "temp = y * 8"
Could you try it? _________________ /// KMT
/// www.muratursavas.com |
meepa123
Posted: Mon Mar 19, 2007 6:43 am |
Thanks!
Problem got solved a bit...
b=20;
a=10;
for(a=1;a<=20;++a)
glcd_pixel(a,b,ON);
now draws a perfect line, but
b=20;
a=10;
for(b=1;b<=20;++b)
glcd_pixel(a,b,ON);
draws random points with some sense of logic... when it just should plot a vertical line.
It's driving me crazy... and the worst of all is, that the driver is from ccs, HDM64GS12.c . I don't know if I am the only person suffering this, but...
thanks!
PD: If I glcd_pixel(0,3,ON) for example, the pixel does not appear there. I think the /8 * 64 has been set intentionally... |
KaraMuraT
Posted: Mon Mar 19, 2007 8:06 am |
it's possibly because of the out of scope values. you should try all the values between 10 and 20 and most probably you'll find a breaking point for those random points. And I guess it will be 16.
This out of scope values probably generating the points after the line you intended. Like using WordWrap with notepad.
I don't have enough brain power to investigate this problem clearly. Because it's monday and I'm reserving some of my gray cells for the movie "300". I'll watch it at the evening ![Cool](images/smiles/icon_cool.gif) _________________ /// KMT
meepa123
Posted: Mon Mar 19, 2007 9:44 am |
May this be bug?
b=20;
a=10;
do
glcd_pixel(a,b,ON);
a=a+1;
b=b+1;
}while(b!=30);
Does not plot anything
b=20;
a=10;
do
a=a+1;
b=b+1;
glcd_pixel(a,b,ON);
}while(b!=30);
Does plot a diagonal line.
The library used is above. It's very strange. And very annoying. Of course, FOR statements don't plot a single point neither.
PD: tried with 18f4680 and 18f452 and same results. |
nome Guest
Posted: Tue Mar 20, 2007 4:00 am |
it may be a bug... dunno what ccs people thinks about it... |
