Function behaves differently... possible bug? ccs 4.023
meepa123
PostPosted: Mon Mar 19, 2007 5:49 am     Reply with quote
Hello
I have a function that plots points at a graphical LCD 128x64. The interface is OK.
b=20;
a=10;
glcd_pixel(a,b,ON);
glcd_pixel(a*2,b*2,ON);
glcd_pixel(a*3,b*3,ON);
glcd_pixel(a+1,b-1,ON);
glcd_pixel(a-1,b+1,ON);
Only the first THREE pixels are set at the lcd. The last two don't appear. I have the same problem, if i do this:
a=10;
for(b=1;b<=20;b++)
glcd_pixel(a,b,ON);
At this case, nothing is at the screen, where a line should appear.
I can't imagine it is a problem of the glcd managing routine, but at least i put the glcd_pixel routine, which may be the conflictive one.
void glcd_pixel(int8 x, int8 y, int1 color)
   int8* p;
   int16 temp;
   temp =  y/8;
   temp *= 64;
   temp += x;
   if(x > 63)
      p = displayData.right + temp - 64;
      p = displayData.left + temp;
   if(color)
      bit_set(*p, y%8);
      bit_clear(*p, y%8);
Where displayData.left and displayData.right are two 512byte arrays. Writing directly at those arrays, and then updating the LCD screen, results in correct data, so LCD fault should be discarded.
I hope you can help me!
PD: This is shocking...
a=10;
do
a++;
glcd_pixel(a,b,ON);
}while(a<=30);
This piece of code does work... and it equals to a for(a=10;a<=30;++a), doesn't it? The for does not work...
KaraMuraT
Re: Function behaves differently... possible bug? ccs 4.023
PostPosted: Mon Mar 19, 2007 6:28 am     Reply with quote
I think your problem is at this lines:
   int16 temp;
   temp =  y/8;
   temp *= 64;
temp = y/8 and than temp *= 64 is very bad way. First of all you're wasting a division cyle which is the longest math operation.
Also Your code is equal to temp = y * 8 but with a difference. Your implementation truncates some values. Because temp is not a float. Therefore adding or subtracting values which are smaller than 8 generates same values. You should use "temp = y * 8"
Could you try it?
/// KMT
/// www.muratursavas.com
meepa123
PostPosted: Mon Mar 19, 2007 6:43 am     Reply with quote
Thanks!
Problem got solved a bit...
b=20;
a=10;
for(a=1;a<=20;++a)
glcd_pixel(a,b,ON);
now draws a perfect line, but
b=20;
a=10;
for(b=1;b<=20;++b)
glcd_pixel(a,b,ON);
draws random points with some sense of logic... when it just should plot a vertical line.
It's driving me crazy... and the worst of all is, that the driver is from ccs, HDM64GS12.c . I don't know if I am the only person suffering this, but...
thanks!
PD: If I glcd_pixel(0,3,ON) for example, the pixel does not appear there. I think the /8 * 64 has been set intentionally...
KaraMuraT
PostPosted: Mon Mar 19, 2007 8:06 am     Reply with quote
it's possibly because of the out of scope values. you should try all the values between 10 and 20 and most probably you'll find a breaking point for those random points. And I guess it will be 16.
This out of scope values probably generating the points after the line you intended. Like using WordWrap with notepad.
I don't have enough brain power to investigate this problem clearly. Because it's monday and I'm reserving some of my gray cells for the movie "300". I'll watch it at the evening Cool
/// KMT
meepa123
PostPosted: Mon Mar 19, 2007 9:44 am     Reply with quote
May this be bug?
b=20;
a=10;
do
glcd_pixel(a,b,ON);
a=a+1;
b=b+1;
}while(b!=30);
Does not plot anything
b=20;
a=10;
do
a=a+1;
b=b+1;
glcd_pixel(a,b,ON);
}while(b!=30);
Does plot a diagonal line.
The library used is above. It's very strange. And very annoying. Of course, FOR statements don't plot a single point neither.
PD: tried with 18f4680 and 18f452 and same results.
nome
PostPosted: Tue Mar 20, 2007 4:00 am     Reply with quote
it may be a bug... dunno what ccs people thinks about it...
