Help with MCP23S17
coblet
Help with MCP23S17
PostPosted: Sun Mar 04, 2007 3:19 pm     Reply with quote
I am trying to use the MCP23S17 to add 16 input to my PIC 18F4580
The value read is always 0, not change. I donīt know what to do. Anybody could help me.
This is my code:
#include <18F4580.h>
#fuses HS, NOPROTECT, NOLVP, NOWDT
#define CS_23S17_1                 PIN_C1
#define RESET_23S17_1            PIN_D0
   int8 data0,data1;
   output_low(RESET_23S17_1 );
   delay_us(10);
   output_high(RESET_23S17_1 );
    setup_spi(SPI_MASTER |SPI_H_TO_L| SPI_CLK_DIV_4);
   output_low(CS_23S17_1);
   spi_write(0x40); /// Opcode write mode
   spi_write(0x00); // WRITE IOCON   //IODIRA
   spi_write(0xff);// // set port A as inputs
   spi_write(0xff);// // set port B as inputs
   output_high(CS_23S17_1);  // disable I/O
   output_low(CS_23S17_1); //enable I/O expander
   spi_write(0x12); // SELECT GPIOA
   data0=spi_read(0);// read GPIOA
   data1=spi_read(0);// read GPIOB
} // main
Thanks in advance
Humberto
PostPosted: Sun Mar 04, 2007 5:55 pm     Reply with quote
I donīt have the MCP23S17 but I wrote this code if you want to test it.
#define IODIRA 0x00
#define IODIRB 0x01
#define GPIOA  0x12
#define GPIOB  0x13
   spi_write(0x40);
   spi_write(IODIRA); // WRITE IOCON
   spi_write(0xFF);     //
   delay_ms(10);
   spi_write(0x40);
   spi_write(IODIRB); // WRITE IOCON
   spi_write(0xFF);     //
       spi_write(0x41);    // READ OPCODE
       data0=spi_read(GPIOA); // read GPIOA
       data1=spi_read(GPIOB); // read GPIOB
       printf("PA %x   PB %x\r\n", data0, data1);
Humberto
coblet
MCP23S17 is now ok
PostPosted: Tue Mar 06, 2007 12:37 pm     Reply with quote
Thanks for your help,
Now the comunications with my MCP23S17 are ok.
The problem was the spi configuration.
With this program I can read 16 input from MCP23S17.
// Includes
//#fuses EC_IO, NOPROTECT, NOLVP,WDT16   fuses 18F458
#define IODIRA 0x00
#define IODIRB 0x01
#define GPIOA  0x12
#define GPIOB  0x13
void lectura_IO_EXPANDER_1(void);
int8 i_GPIOA_MCP1;
int8 i_GPIOB_MCP1;
 setup_spi(SPI_MASTER |0X4000| SPI_CLK_DIV_4);//16
  bit_set(*0xFC6, 5); // SSPCON1.SSPEN = 1
  bit_set(*0xFC7, 6); // SSPSTAT.CKE = 1
   spi_write(0x40);
   spi_write(0xFF);     //
   delay_us(10);
   spi_write(0x40);
   spi_write(0xFF);     //
  lectura_IO_EXPANDER_1();
      delay_us(100);
} // main
    spi_write(0x12); // GPIOA SELECT GPIOA
    i_GPIOA_MCP1=spi_read(0); // read GPIOA
    i_GPIOB_MCP1=spi_read(0); // read GPIOB
Humberto
PostPosted: Tue Mar 06, 2007 12:42 pm     Reply with quote
Just curious, in your code I donīt see any code to watch the variables i_GPIOA_MCP1.
How do you "see" the inputs values ?
Humberto
coblet
variable i_GPIOA_MCP1
PostPosted: Tue Mar 06, 2007 1:03 pm     Reply with quote
I send this variables with RS232 protocol to my PC (in the PC I have one application with C++).
