coblet
Help with MCP23S17 |
Posted: Sun Mar 04, 2007 3:19 pm |
I am trying to use the MCP23S17 to add 16 input to my PIC 18F4580
The value read is always 0, not change. I donīt know what to do. Anybody could help me.
This is my code:
#include <18F4580.h>
#fuses HS, NOPROTECT, NOLVP, NOWDT
#define CS_23S17_1 PIN_C1
#define RESET_23S17_1 PIN_D0
int8 data0,data1;
output_low(RESET_23S17_1 );
delay_us(10);
output_high(RESET_23S17_1 );
setup_spi(SPI_MASTER |SPI_H_TO_L| SPI_CLK_DIV_4);
output_low(CS_23S17_1);
spi_write(0x40); /// Opcode write mode
spi_write(0x00); // WRITE IOCON //IODIRA
spi_write(0xff);// // set port A as inputs
spi_write(0xff);// // set port B as inputs
output_high(CS_23S17_1); // disable I/O
output_low(CS_23S17_1); //enable I/O expander
spi_write(0x12); // SELECT GPIOA
data0=spi_read(0);// read GPIOA
data1=spi_read(0);// read GPIOB
} // main
Thanks in advance |
Humberto
Posted: Sun Mar 04, 2007 5:55 pm |
I donīt have the MCP23S17 but I wrote this code if you want to test it.
#define IODIRA 0x00
#define IODIRB 0x01
#define GPIOA 0x12
#define GPIOB 0x13
spi_write(0x40);
spi_write(IODIRA); // WRITE IOCON
spi_write(0xFF); //
delay_ms(10);
spi_write(0x40);
spi_write(IODIRB); // WRITE IOCON
spi_write(0xFF); //
spi_write(0x41); // READ OPCODE
data0=spi_read(GPIOA); // read GPIOA
data1=spi_read(GPIOB); // read GPIOB
printf("PA %x PB %x\r\n", data0, data1);
Humberto |
coblet
MCP23S17 is now ok |
Posted: Tue Mar 06, 2007 12:37 pm |
Thanks for your help,
Now the comunications with my MCP23S17 are ok.
The problem was the spi configuration.
With this program I can read 16 input from MCP23S17.
// Includes
//#fuses EC_IO, NOPROTECT, NOLVP,WDT16 fuses 18F458
#define IODIRA 0x00
#define IODIRB 0x01
#define GPIOA 0x12
#define GPIOB 0x13
void lectura_IO_EXPANDER_1(void);
int8 i_GPIOA_MCP1;
int8 i_GPIOB_MCP1;
setup_spi(SPI_MASTER |0X4000| SPI_CLK_DIV_4);//16
bit_set(*0xFC6, 5); // SSPCON1.SSPEN = 1
bit_set(*0xFC7, 6); // SSPSTAT.CKE = 1
spi_write(0x40);
spi_write(0xFF); //
delay_us(10);
spi_write(0x40);
spi_write(0xFF); //
lectura_IO_EXPANDER_1();
delay_us(100);
} // main
spi_write(0x12); // GPIOA SELECT GPIOA
i_GPIOA_MCP1=spi_read(0); // read GPIOA
i_GPIOB_MCP1=spi_read(0); // read GPIOB
Humberto
Posted: Tue Mar 06, 2007 12:42 pm |
Just curious, in your code I donīt see any code to watch the variables i_GPIOA_MCP1.
How do you "see" the inputs values ?
Humberto |
coblet
variable i_GPIOA_MCP1 |
Posted: Tue Mar 06, 2007 1:03 pm |
I send this variables with RS232 protocol to my PC (in the PC I have one application with C++). |
