iw2nzm
PIC18F4520 delay issue |
Posted: Fri Feb 23, 2007 5:55 am |
Hi!
I'm running a PIC18F4520 with a 10 MHz xtal and x4 pll enabled. There is only a LED on PIN_A0 to test if the uC is alive. Compiler version is 4.025.
My oscilloscope confirms a nice 10 MHz sine wave on osc1 and osc2 pins.
But PIN_A0 toggles about every 7.5 us instead 500 ms as expected.
Here is the code:
#include <18F4520.h>
#FUSES WDT64 //Watch Dog Timer uses 1:64 Postscale
#FUSES H4 //High speed osc with HW enabled 4X PLL
#FUSES BORV25 //Brownout reset at 2.5V
#FUSES PUT //Power Up Timer
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOLPT1OSC //Timer1 configured for higher power operation
#FUSES XINST //Extended set extension and Indexed Addressing mode enabled
#use delay(clock=40M, oscillator=10M, RESTART_WDT)
#use rs232(baud = 9600, parity = N, xmit = RS232_TX, rcv = RS232_RX, bits = 8, stream = SFC, enable = PIN_B1, restart_wdt)
setup_psp(PSP_DISABLED);
setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4);
setup_wdt(WDT_ON);
setup_timer_0(RTCC_INTERNAL);
setup_timer_2(T2_DIV_BY_16,255,1);
setup_ccp1(CCP_PWM_FULL_BRIDGE|CCP_SHUTDOWN_ON_INT0|CCP_SHUTDOWN_AC_L|CCP_SHUTDOWN_BD_L);
setup_ccp2(CCP_PWM);
set_pwm1_duty(512);
set_pwm2_duty(512);
setup_vref(FALSE);
enable_interrupts(INT_EXT);
enable_interrupts(INT_RDA);
enable_interrupts(INT_SSP);
setup_oscillator(False);
for (;;) {
output_toggle(PIN_A0);
restart_wdt();
It's not the first time a use this MCU.... what do I miss?
Thanks,
Marco / iw2nzm |
Posted: Fri Feb 23, 2007 7:06 am |
Code: | enable_interrupts(INT_TIMER0);
enable_interrupts(GLOBAL); | Is this the actual program you are testing with? You activate a lot of interrupts but in the posted code there are no interrupt handling routines, this could cause all kind of problems.
What happens when you change the code to disable the watchdog? (add fuse NOWDT and change the call to setup_wdt() ).
Code: | #use delay(clock=40M, oscillator=10M, RESTART_WDT) | This has changed in v4.xxx and I don't know how well tested this is. Test what happens when you revert to Code: | #use delay(clock=40000000, RESTART_WDT) |
iw2nzm
Posted: Fri Feb 23, 2007 9:44 am |
ckielstra wrote: | Is this the actual program you are testing with? You activate a lot of interrupts but in the posted code there are no interrupt handling routines, this could cause all kind of problems. |
The actual program contains empty handling routines like this:
#int_TIMER0
void TIMER0_isr(void)
Below I copy the whole code, there also a lot of #define but they should not be a trouble.
Quote: |
What happens when you change the code to disable the watchdog? (add fuse NOWDT and change the call to setup_wdt() ). |
Nothing. I already tried this.
As before, I have just tried again with no difference.
The PIC seems alive because the clock is running and I can change the I/O lines.
I also disabled interrupts, nothing to do.
Bye
Marco / iw2nzm
the whole code:
#FUSES NOWDT //Watch Dog Timer uses 1:64 Postscale
#define ADC_DATA_IN PIN_A0
#define ADC_DATA_OUT PIN_A1
#define ADC_CS PIN_A2
#define ADC_CK PIN_A3
#define ADC_EOC PIN_A4
#define COMPASS_ENB PIN_A5
#define COMPASS_DATA_READY PIN_B0
#define RS485_ENB PIN_B1
#define DAC_LOAD PIN_B2
#define DAC_LDAC PIN_B3
#define A0 PIN_B4
#define A1 PIN_B5
#define A2 PIN_B6
#define RTC_DATA PIN_B7
#define COMPASS_RX PIN_C0
#define PWM2 PIN_C1
#define PWM1 PIN_C2
#define SPI_CLK PIN_C3
#define SPI_DI PIN_C4
#define SPI_DO PIN_C5
#define RS232_TX PIN_C6
#define RS232_RX PIN_C7
#define BUS_D0 PIN_D0
#define BUS_D1 PIN_D1
#define BUS_D2 PIN_D2
#define BUS_D3 PIN_D3
#define BUS_D4 PIN_D4
#define BUS_D5 PIN_D5
#define BUS_D6 PIN_D6
#define BUS_D7 PIN_D7
#define OSD_CS PIN_E0
#define OSC_SCL PIN_E1
#define OSC_SDA PIN_E2
#use rs232(baud = 9600, parity = N, xmit = RS232_TX, rcv = RS232_RX, bits = 8, stream = SFC, enable = RS485_ENB, restart_wdt)
#int_TIMER0
#int_TIMER1
void TIMER1_isr(void)
#int_TIMER2
void TIMER2_isr(void)
#int_EXT
void EXT_isr(void)
#int_RDA
void RDA_isr(void)
#int_SSP
void SSP_isr(void)
setup_wdt(WDT_ON);
set_pwm1_duty(512);
set_pwm2_duty(512);
setup_vref(FALSE);
disable_interrupts(GLOBAL);
//setup_oscillator(False);
for (;;) {
//restart_wdt();
Posted: Fri Feb 23, 2007 10:50 am |
Quote: | #FUSES XINST //Extended set extension and Indexed Addressing mode enabled |
CCS doesn't support the extended instruction set. Change that
fuse to NOXINST. |
Posted: Fri Feb 23, 2007 10:51 am |
Two things.
As shown, add a 'getc', to the INT_RDA handler. Alone of the interrupts shown, this one, if enabled, and the serial input line drops, will cause the PIC to hang completely, if the character is not read in the handler. Though you have the global interrupt disabled, this is worth doing to avoid potential problems.
Turn off the XINST fuse.
Though the new compiler, may be starting to use the extended instructions, this instruction would cause problems for the older compilers, and I'd not trust the new compilers on this....
iw2nzm
Posted: Fri Feb 23, 2007 11:37 am |
PCM programmer wrote: |
fuse to NOXINST. |
This was my fault.
Now it works fine. Thank you and thanks to Ttelmah too.
Marco / iw2nzm |
