PIC18F4520 delay issue
iw2nzm
PostPosted: Fri Feb 23, 2007 5:55 am     Reply with quote
Hi!
I'm running a PIC18F4520 with a 10 MHz xtal and x4 pll enabled. There is only a LED on PIN_A0 to test if the uC is alive. Compiler version is 4.025.
My oscilloscope confirms a nice 10 MHz sine wave on osc1 and osc2 pins.
But PIN_A0 toggles about every 7.5 us instead 500 ms as expected.
Here is the code:
#include <18F4520.h>
#FUSES WDT64                    //Watch Dog Timer uses 1:64 Postscale
#FUSES H4                       //High speed osc with HW enabled 4X PLL
#FUSES NOPROTECT                //Code not protected from reading
#FUSES BORV25                   //Brownout reset at 2.5V
#FUSES PUT                      //Power Up Timer
#FUSES NOCPD                    //No EE protection
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES NOPBADEN                 //PORTB pins are configured as digital I/O on RESET
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOLPT1OSC                //Timer1 configured for higher power operation
#FUSES MCLR                     //Master Clear pin enabled
#FUSES XINST                    //Extended set extension and Indexed Addressing mode enabled
#use delay(clock=40M, oscillator=10M, RESTART_WDT)
#use rs232(baud = 9600, parity = N, xmit = RS232_TX, rcv = RS232_RX, bits = 8, stream = SFC, enable = PIN_B1, restart_wdt)
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4);
   setup_wdt(WDT_ON);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
   setup_timer_2(T2_DIV_BY_16,255,1);
   setup_ccp1(CCP_PWM_FULL_BRIDGE|CCP_SHUTDOWN_ON_INT0|CCP_SHUTDOWN_AC_L|CCP_SHUTDOWN_BD_L);
   setup_ccp2(CCP_PWM);
   set_pwm1_duty(512);
   set_pwm2_duty(512);
   setup_vref(FALSE);
   enable_interrupts(INT_EXT);
   enable_interrupts(INT_RDA);
   enable_interrupts(INT_SSP);
   setup_oscillator(False);
   for (;;) {
      output_toggle(PIN_A0);
      restart_wdt();
It's not the first time a use this MCU.... what do I miss?
Thanks,
Marco / iw2nzm
PostPosted: Fri Feb 23, 2007 7:06 am     Reply with quote
Is this the actual program you are testing with? You activate a lot of interrupts but in the posted code there are no interrupt handling routines, this could cause all kind of problems.
What happens when you change the code to disable the watchdog? (add fuse NOWDT and change the call to setup_wdt() ).
This has changed in v4.xxx and I don't know how well tested this is. Test what happens when you revert to
#use delay(clock=40000000, RESTART_WDT)
iw2nzm
PostPosted: Fri Feb 23, 2007 9:44 am     Reply with quote
The actual program contains empty handling routines like this:
#int_TIMER0
void  TIMER0_isr(void)
Below I copy the whole code, there also a lot of #define but they should not be a trouble.
Nothing. I already tried this.
As before, I have just tried again with no difference.
The PIC seems alive because the clock is running and I can change the I/O lines.
I also disabled interrupts, nothing to do.
Bye
Marco / iw2nzm
the whole code:
#FUSES NOWDT                    //Watch Dog Timer uses 1:64 Postscale
#define ADC_DATA_IN         PIN_A0
#define ADC_DATA_OUT         PIN_A1
#define ADC_CS               PIN_A2
#define ADC_CK               PIN_A3
#define ADC_EOC            PIN_A4
#define COMPASS_ENB         PIN_A5
#define COMPASS_DATA_READY PIN_B0
#define RS485_ENB            PIN_B1
#define DAC_LOAD            PIN_B2
#define DAC_LDAC            PIN_B3
#define A0                  PIN_B4
#define A1                  PIN_B5
#define A2                  PIN_B6
#define RTC_DATA            PIN_B7
#define COMPASS_RX         PIN_C0
#define PWM2               PIN_C1
#define PWM1               PIN_C2
#define SPI_CLK            PIN_C3
#define SPI_DI               PIN_C4
#define SPI_DO               PIN_C5
#define RS232_TX            PIN_C6
#define RS232_RX            PIN_C7
#define BUS_D0               PIN_D0
#define BUS_D1               PIN_D1
#define BUS_D2               PIN_D2
#define BUS_D3               PIN_D3
#define BUS_D4               PIN_D4
#define BUS_D5               PIN_D5
#define BUS_D6               PIN_D6
#define BUS_D7               PIN_D7
#define OSD_CS               PIN_E0
#define OSC_SCL            PIN_E1
#define OSC_SDA            PIN_E2
#use rs232(baud = 9600, parity = N, xmit = RS232_TX, rcv = RS232_RX, bits = 8, stream = SFC, enable = RS485_ENB, restart_wdt)
#int_TIMER0
#int_TIMER1
void  TIMER1_isr(void)
#int_TIMER2
void  TIMER2_isr(void)
#int_EXT
void  EXT_isr(void)
#int_RDA
void  RDA_isr(void)
#int_SSP
void  SSP_isr(void)
   setup_wdt(WDT_ON);
   set_pwm1_duty(512);
   set_pwm2_duty(512);
   setup_vref(FALSE);
   disable_interrupts(GLOBAL);
   //setup_oscillator(False);
   for (;;) {
      //restart_wdt();
PostPosted: Fri Feb 23, 2007 10:50 am     Reply with quote
CCS doesn't support the extended instruction set. Change that
fuse to NOXINST.
PostPosted: Fri Feb 23, 2007 10:51 am     Reply with quote
Two things.
As shown, add a 'getc', to the INT_RDA handler. Alone of the interrupts shown, this one, if enabled, and the serial input line drops, will cause the PIC to hang completely, if the character is not read in the handler. Though you have the global interrupt disabled, this is worth doing to avoid potential problems.
Turn off the XINST fuse.
Though the new compiler, may be starting to use the extended instructions, this instruction would cause problems for the older compilers, and I'd not trust the new compilers on this....
iw2nzm
PostPosted: Fri Feb 23, 2007 11:37 am     Reply with quote
fuse to NOXINST.
This was my fault. Rolling Eyes
Now it works fine. Thank you and thanks to Ttelmah too.
Marco / iw2nzm
