Work MMC source Code & Simulation
Goto page 1, 2  Next
Rafet32
PostPosted: Thu Jul 20, 2006 4:09 am     Reply with quote
Merhaba
MMC ile ilgili denediğim çalışan bir uygulamayı sizlerle paylaşmak istedim. Ekteki dosyalarda kaynak kodları (CCS) ve Proteus 6.9 ile yapılmış simülasyon dosyası mevcuttur.
Faydalı olmak dileği ile....
Proteusda çizilmiş şematik devre
Proteusdaki devrenin çalışır hali
Source Code and SimulationFile Download
PostPosted: Thu Jul 20, 2006 7:59 am     Reply with quote
My Turkish is very poor. Is it possible you post an English translation as well?
Rafet32
PostPosted: Thu Jul 20, 2006 12:50 pm     Reply with quote
Hi
Sorry. My english is very poor.
Above download link include tested source code and proteus simulation file.
Version?
PostPosted: Sat Jul 22, 2006 4:25 pm     Reply with quote
Wich version of proteus have you used? Thanks!
Rafet32
Re: Version?
PostPosted: Sun Jul 23, 2006 2:00 pm     Reply with quote
Proteus 6.9 SP4
_erhan_
PostPosted: Thu Aug 24, 2006 8:02 am     Reply with quote
IN ENGLISH : (images same as above) (Sorry i cannot post links or urls)
I want to share a working circuit that i tested.
File given as attachement contains source codes(CCS) and Proteus 6.9 (SP4) simulation file.
I hope it will be helpful.
schematic:
img132.imageshack.us/img132/8716/proteusstopnu8.jpg
Simulation running on proteus:
img80.imageshack.us/img80/8939/proteussimat9.jpg
DOWNLOAD Source Code and Simulation File :
rapidshare.de/files/26386301/Forum_mmc.rar.html
gedo
Hay ALLAH razı olsun
PostPosted: Sun Oct 01, 2006 9:29 am     Reply with quote
bende isite mi problem yazdığım kodlarda mı problem diye boğuşup duruyordum.
sayende isite problem olmadığını gördüm. şimdi tam gaz giderim. hemde kodlarından da faydalanırım.
ldz2000
error!
PostPosted: Thu Jan 25, 2007 1:26 am     Reply with quote
I Can't download "forum_mmc.rar"??
Rafet32
PostPosted: Sat Jan 27, 2007 3:12 pm     Reply with quote
Send files your mail adress
Andreas
PostPosted: Sun Jan 28, 2007 2:36 am     Reply with quote
Hello Rafet !
Looks very easy !!!
I am trying to run SD Cards on a 8720, but had some troubles in the past, so I am interested how You found the solution.
Please can You send me the sourcecode to my email address ?
apo@csie-data.com
Thank You very much
Andreas
Rafet32
PostPosted: Sun Jan 28, 2007 3:29 pm     Reply with quote
Hi
Old download link invalid.
Im upload again rapid-share source code and simulation files
New Download link is belove:
http://rapidshare.com/files/13846919/Forum_mmc.rar.html
Link fixed. Verified working 5/29/2008.
-- Forum Moderator
prince
erreur
PostPosted: Thu Feb 15, 2007 5:45 pm     Reply with quote
Andreas wrote:
Hello Rafet !
amir_isecs@yahoo.fr
Thank You very much
asmallri
PostPosted: Thu Feb 15, 2007 7:12 pm     Reply with quote
The schematic has a (common) hardware design flaw. The DO output of the SD/MMC card at 3.3 volts is not compatible with the input specification of a 5 volt PIC SPI input in SPI mode. The SDO, SCK and CS require level conversion from 5volt to 3.3volts.
Regards, Andrew
Rafet32
PostPosted: Fri Feb 16, 2007 3:56 pm     Reply with quote
Your right asmallri
Real hardware design, necessary 5V signal to reduce 3.3V.
Mustafa
PostPosted: Thu Feb 22, 2007 1:42 am     Reply with quote
Selam Rafet
rapidshare de linkler download edilemiyor. benimde mail adresime yollayabilirsen sevinirim.
trspider1970@yahoo.com
şimdiden teşekkürler.
Goto page 1, 2  Next
Page 1 of 2
