Rafet32
Work MMC source Code & Simulation |
Posted: Thu Jul 20, 2006 4:09 am |
Merhaba
MMC ile ilgili denediğim çalışan bir uygulamayı sizlerle paylaşmak istedim. Ekteki dosyalarda kaynak kodları (CCS) ve Proteus 6.9 ile yapılmış simülasyon dosyası mevcuttur.
Faydalı olmak dileği ile....
Proteusda çizilmiş şematik devre
Proteusdaki devrenin çalışır hali
Source Code and SimulationFile Download |
Posted: Thu Jul 20, 2006 7:59 am |
My Turkish is very poor. Is it possible you post an English translation as well? |
Rafet32
Posted: Thu Jul 20, 2006 12:50 pm |
Hi
Sorry. My english is very poor.
Above download link include tested source code and proteus simulation file. |
Version? |
Posted: Sat Jul 22, 2006 4:25 pm |
Wich version of proteus have you used? Thanks! |
Rafet32
Re: Version? |
Posted: Sun Jul 23, 2006 2:00 pm |
Anonymous wrote: | Wich version of proteus have you used? Thanks! |
Proteus 6.9 SP4 |
_erhan_ Guest
Posted: Thu Aug 24, 2006 8:02 am |
IN ENGLISH : (images same as above) (Sorry i cannot post links or urls)
I want to share a working circuit that i tested.
File given as attachement contains source codes(CCS) and Proteus 6.9 (SP4) simulation file.
I hope it will be helpful.
schematic:
Code: | img132.imageshack.us/img132/8716/proteusstopnu8.jpg |
Simulation running on proteus:
Code: | img80.imageshack.us/img80/8939/proteussimat9.jpg |
DOWNLOAD Source Code and Simulation File :
Code: | rapidshare.de/files/26386301/Forum_mmc.rar.html |
gedo
Hay ALLAH razı olsun |
Posted: Sun Oct 01, 2006 9:29 am |
bende isite mi problem yazdığım kodlarda mı problem diye boğuşup duruyordum.
sayende isite problem olmadığını gördüm. şimdi tam gaz giderim. hemde kodlarından da faydalanırım. |
ldz2000
error! |
Posted: Thu Jan 25, 2007 1:26 am |
I Can't download "forum_mmc.rar"?? |
Rafet32
Posted: Sat Jan 27, 2007 3:12 pm |
Send files your mail adress |
Andreas
Posted: Sun Jan 28, 2007 2:36 am |
Hello Rafet !
Looks very easy !!!
I am trying to run SD Cards on a 8720, but had some troubles in the past, so I am interested how You found the solution.
Please can You send me the sourcecode to my email address ?
apo@csie-data.com
Thank You very much
Andreas |
Rafet32
prince Guest
erreur |
Posted: Thu Feb 15, 2007 5:45 pm |
Andreas wrote: | Hello Rafet !
amir_isecs@yahoo.fr
Thank You very much
asmallri
Posted: Thu Feb 15, 2007 7:12 pm |
The schematic has a (common) hardware design flaw. The DO output of the SD/MMC card at 3.3 volts is not compatible with the input specification of a 5 volt PIC SPI input in SPI mode. The SDO, SCK and CS require level conversion from 5volt to 3.3volts. _________________ Regards, Andrew
Rafet32
Posted: Fri Feb 16, 2007 3:56 pm |
Your right asmallri
Real hardware design, necessary 5V signal to reduce 3.3V. |
Mustafa Guest
Posted: Thu Feb 22, 2007 1:42 am |
Selam Rafet
rapidshare de linkler download edilemiyor. benimde mail adresime yollayabilirsen sevinirim.
trspider1970@yahoo.com
şimdiden teşekkürler. |
