I use the 16F676 in several applications, all with sleep function it works. Now I have a new project but the PIC doesnīt enter the sleep mode!
EXT_INT_EDGE(L_TO_H);
sleep();
I want to wake up the PIC with Ext interrupt, but the current after the sleep(); is the same as before. I also have the ICD header for this PIC - when debugging the code has no effect!
Whatīs wrong?
Posted: Wed Feb 07, 2007 2:45 pm
Read the Help File in MPLAB for the ICD2. Look at the
section on Limitations for the 16F676. It says:
The SLEEP instruction cannot be used when debugging.
