I setup 10 bytes as an array. I'm using the INT_RDA to populate it with a fixed 8 bytes and they are all there in the correct order. However, at times my index is off by +1, yet my pointer isn't. I can see in the MPLAB Watch Window that the pointer is 0 and yet the data is offset by 1. I cannot seem to clear this condition without a hard reset.
kender
Posted: Mon Dec 04, 2006 7:18 pm
Please post the version of your CCS compiler and the type of your particular PIC chip!
If the version is 4.xxx, please also read the sticky about the V4 issues.
