I'd like to get the latest MPLAB because I want to use the included PCB compiler for a new project. My problem is that my current MPLAB installation (v6.6) is very stable and is working well with PCM v3.249, and I don't want to put all that in the weeds by "upgrading". Is the process relatively simple and painless, or will I need to set everything up again?
Steve
SET
Posted: Wed Nov 15, 2006 12:45 pm
We have upgraded from MPLAB 6.x to (currently) 7.3 - no issues that I can remember, other than had to run the little CCS utility to integrate the compiler back into the IDE.
HTH?
