No speed change between EC_IO and H4
vwpete
PostPosted: Wed Aug 23, 2006 9:14 pm     Reply with quote
In the code below I'm toggling pin D2 and measuring with a scope.
When I swap EC_IO for H4 I don't see a speed difference on D2.
It should be 4x quicker no? The config bits are changing in Mplab.
Thanks, Pete
PCH 3.249
18f452
10mhz TTL osc to osc1
Using ICD2 and Mplab
#include <18F452.h>
#fuses H4,NOWDT,NOPROTECT,NOLVP,PUT
void main(){
for(;;){
          output_high(pin_d2);
          output_low(pin_d2);
PostPosted: Wed Aug 23, 2006 9:22 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=20827
vwpete
PostPosted: Wed Aug 23, 2006 9:54 pm     Reply with quote
Doh! I should have searched first. The reset was it.
Thanks for the quick help. I can go to bed now Smile
Pete
