In the code below I'm toggling pin D2 and measuring with a scope.
When I swap EC_IO for H4 I don't see a speed difference on D2.
It should be 4x quicker no? The config bits are changing in Mplab.
Thanks, Pete
PCH 3.249
18f452
10mhz TTL osc to osc1
Using ICD2 and Mplab
