MCP3201 (microchip) is 12 bit adc
oyhan
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Fri Aug 11, 2006 1:25 am     Reply with quote
Dear Friends..
MCP3201 is 12 bit adc on SPI communication. Below is sample program that is not working. Can some one guide me where is mistake. Thanks..
#include <16F88.h>
#fuses INTRC_IO, MCLR, NOWDT, NOPROTECT, NOBROWNOUT, PUT, NOLVP
#use delay(clock=8000000)
#include "flex_lcd.c"
#define Dout   PIN_B0
#define CLK   PIN_B1
#define CS   PIN_A0
// Define the register addresses for ANSEL and CMCON.
#byte ANSEL = 0x9B
#byte CMCON = 0x9C
BYTE read_adc_byte(BYTE number_of_bits) {
   BYTE i,data;
   data=0;
   for(i=0;i<number_of_bits;++i) {
      output_low(CLK);
      delay_us(50);
      shift_left(&data,1,input(Dout));
      output_high(CLK);
      delay_us(50);
   return(data);
{  int  data_l;
   long int data_h, value;
   float result;
   data_h=0;
   data_l=0;
   set_tris_a(0b11100000);  set_tris_b(0b00000001);
   ANSEL = 0;  // Set all A/D pins to digital
   CMCON = 7;  // Disable comparators
   setup_adc(ADC_OFF);   output_high(PIN_A1); output_high(PIN_A2); output_high(PIN_A3); output_high(PIN_A4);
   lcd_init();  delay_ms(500);  lcd_putc("Value:");
while(1) {
      output_high(CS);
      delay_us(1);
      output_low(CS);
      data_h = read_adc_byte(9);
      data_l = read_adc_byte(4);
      output_high(CS);
      value = (data_h << 4) | data_l;
      lcd_gotoxy(7,1);
      printf(lcd_putc,"%0Lu",value);
      delay_ms(250); delay_ms(250);
oyhan
PostPosted: Fri Aug 11, 2006 3:46 pm     Reply with quote
PostPosted: Fri Aug 11, 2006 3:49 pm     Reply with quote
CCS has many examples of how to do software SPI read operations.
They use the shift_left() function. Look at the MCP3204 driver for
an example. It's in this folder: c:\Program Files\Picc\Drivers
akokyaw
MCP3202
PostPosted: Sun Aug 13, 2006 1:08 am     Reply with quote
Try this code,
#include <16F877.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)  // Jumpers: 8 to 11, 7 to 12
#define CLK  PIN_B0
#define Dout PIN_B1
#define Din  PIN_B2
#define CS   PIN_B3
void ShiftOut (int data, int no_of_bit)
   int i;
   for(i=0 ; i<no_of_bit>>= 1;
      output_high(CLK);
      delay_us(50);
   BYTE i,data;
   data=0;
      output_low(CLK);
      delay_us(50);
      output_high(CLK);
      delay_us(50);
   return(data);
   int  data_l;
   float result;
   data_h=0;
   data_l=0;
   printf("\r****  Initializing of MCP3202 12 Bit A/D Converter ****\n ");
   while(1) {
      output_high(CS);
      delay_us(1);
      output_low(CS);
      ShiftOut(0b00001100, 4);
   output_high(CS);
   result = value * 0.001226;
      printf("\rOutput Voltage = %f V", result);
hope it will help you,
regards,
ako
oyhan
PostPosted: Sun Aug 13, 2006 5:29 am     Reply with quote
Thanks akokyaw But I want to use mcp3201 . Only 3 Data port and only Dout . It Does not use DIn. I thing I convert your code for mcp 3201 but It did not run. (New code is in my first message) I saw some problem. For example (for any voltage between 0-5V); Always.. First time Value = 03071 and second time is Value=1024 totaly is 4095. I think it musn't change this value but I do not understand why?? I have to see only one Value on the lcd why not?? Help me please..
Best Regards..
PostPosted: Sun Aug 13, 2006 2:44 pm     Reply with quote
I didn't analyze your code in detail, but I can see one problem.
You're calling the "read_adc_byte()" function, and requesting it to
get a 9-bit value. Example: read_adc_byte(9);
But the function puts the data into a byte (8-bits), and it returns a byte.
It can't get 9 bits. You need to create a "read_adc_word()" function
that can get up to 16 bits.
