oyhan
| MCP3201 (microchip) is 12 bit adc |
Posted: Fri Aug 11, 2006 1:25 am |
Dear Friends..
MCP3201 is 12 bit adc on SPI communication. Below is sample program that is not working. Can some one guide me where is mistake. Thanks..
#include <16F88.h>
#fuses INTRC_IO, MCLR, NOWDT, NOPROTECT, NOBROWNOUT, PUT, NOLVP
#use delay(clock=8000000)
#include "flex_lcd.c"
#define Dout PIN_B0
#define CLK PIN_B1
#define CS PIN_A0
// Define the register addresses for ANSEL and CMCON.
#byte ANSEL = 0x9B
#byte CMCON = 0x9C
BYTE read_adc_byte(BYTE number_of_bits) {
BYTE i,data;
data=0;
for(i=0;i<number_of_bits;++i) {
output_low(CLK);
delay_us(50);
shift_left(&data,1,input(Dout));
output_high(CLK);
delay_us(50);
return(data);
{ int data_l;
long int data_h, value;
float result;
data_h=0;
data_l=0;
set_tris_a(0b11100000); set_tris_b(0b00000001);
ANSEL = 0; // Set all A/D pins to digital
CMCON = 7; // Disable comparators
setup_adc(ADC_OFF); output_high(PIN_A1); output_high(PIN_A2); output_high(PIN_A3); output_high(PIN_A4);
lcd_init(); delay_ms(500); lcd_putc("Value:");
while(1) {
output_high(CS);
delay_us(1);
output_low(CS);
data_h = read_adc_byte(9);
data_l = read_adc_byte(4);
output_high(CS);
value = (data_h << 4) | data_l;
lcd_gotoxy(7,1);
printf(lcd_putc,"%0Lu",value);
delay_ms(250); delay_ms(250);
oyhan
Posted: Fri Aug 11, 2006 3:46 pm |
| Can some one guide me where is mistake. Thanks.. |
Posted: Fri Aug 11, 2006 3:49 pm |
CCS has many examples of how to do software SPI read operations.
They use the shift_left() function. Look at the MCP3204 driver for
an example. It's in this folder: c:\Program Files\Picc\Drivers |
akokyaw
| MCP3202 |
Posted: Sun Aug 13, 2006 1:08 am |
Try this code,
| Code: | #include <16F877.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7) // Jumpers: 8 to 11, 7 to 12
#define CLK PIN_B0
#define Dout PIN_B1
#define Din PIN_B2
#define CS PIN_B3
void ShiftOut (int data, int no_of_bit)
int i;
for(i=0 ; i<no_of_bit>>= 1;
output_high(CLK);
delay_us(50);
BYTE i,data;
data=0;
output_low(CLK);
delay_us(50);
output_high(CLK);
delay_us(50);
return(data);
int data_l;
float result;
data_h=0;
data_l=0;
printf("\r**** Initializing of MCP3202 12 Bit A/D Converter ****\n ");
while(1) {
output_high(CS);
delay_us(1);
output_low(CS);
ShiftOut(0b00001100, 4);
output_high(CS);
result = value * 0.001226;
printf("\rOutput Voltage = %f V", result);
hope it will help you,
regards,
ako |
oyhan
Posted: Sun Aug 13, 2006 5:29 am |
Thanks akokyaw But I want to use mcp3201 . Only 3 Data port and only Dout . It Does not use DIn. I thing I convert your code for mcp 3201 but It did not run. (New code is in my first message) I saw some problem. For example (for any voltage between 0-5V); Always.. First time Value = 03071 and second time is Value=1024 totaly is 4095. I think it musn't change this value but I do not understand why?? I have to see only one Value on the lcd why not?? Help me please..
Best Regards.. |
Posted: Sun Aug 13, 2006 2:44 pm |
I didn't analyze your code in detail, but I can see one problem.
You're calling the "read_adc_byte()" function, and requesting it to
get a 9-bit value. Example: read_adc_byte(9);
But the function puts the data into a byte (8-bits), and it returns a byte.
It can't get 9 bits. You need to create a "read_adc_word()" function
that can get up to 16 bits. |
