Since my analog expertise stinks, I thought I would ask you guys on your opinion.
I want to drive some super bright LED's. Their rated current is 20mA. I will be using a 12V battery as the supply. I will have three LED's in series and then use a resistor(or whatever) to limit the current and drop the remaining voltage. My dilema..
As the voltage drops the current will also drop and reduce the brightness of the LED's. I want to be able to keep the current at 20mA regardless of the voltage of the battery. What IC's or descrete components would work for this?
Ronald
treitmey
Posted: Wed Jun 14, 2006 8:21 pm
My favorite for driving one or two LEDS from 12V just uses a bipolar transistor (2N3904) and a resistor if your PIC voltage is regulated. Drive the base from the PIC pin and connect a resistor (220 Ohms for 20mA and VCC=5V) from the emitter to GND. Then connect the LEDs in series from +12V to the collector. Three LEDs may have a problem if the LED voltage is high or the +12V is low. You will have to do the math for your application. Things will drift a little with temperature, but not enough for the eye to see. _________________ The search for better is endless. Instead simply find very good and get the job done.
Humberto
Posted: Thu Jun 15, 2006 6:33 am
The key for this is to use a constant current source that deliver the expected constant 20mA AND a couple of voltage comparator wired as window comparator that enable the whole functioning only if the battery voltage is within an expected adjustable range, ie:
An upper comparator that watch if the battery voltage is under Vmax(adj).
A lower comparator that watch if the battery voltage is over Vmin(adj).
Each comparator with open colector output and OR wired with a pull up resistor tied from 5V. If the battery voltage is outside of the expected value, the comparator output will generate a Shut-Down level to switch off the whole circuit.
This way the circuit should keep a constant brightness of the LED's regardless of the battery voltage drops.
