Constant current supply
rnielsen
PostPosted: Wed Jun 14, 2006 4:24 pm     Reply with quote
Since my analog expertise stinks, I thought I would ask you guys on your opinion.
I want to drive some super bright LED's. Their rated current is 20mA. I will be using a 12V battery as the supply. I will have three LED's in series and then use a resistor(or whatever) to limit the current and drop the remaining voltage. My dilema..
As the voltage drops the current will also drop and reduce the brightness of the LED's. I want to be able to keep the current at 20mA regardless of the voltage of the battery. What IC's or descrete components would work for this?
Ronald
treitmey
PostPosted: Wed Jun 14, 2006 4:51 pm     Reply with quote
Try this.
http://www.discovercircuits.com/PDF-FILES/NewPDF/CONSTANTCURRETLED1.pdf
If you drive more than 1 then there are special circuits for that.
http://rocky.digikey.com/WebLib/Texas%20Instruments/Web%20data/TPIC2810.pdf
and the TPIC6C595 for relays
and this one looks good.
http://focus.ti.com/lit/ds/symlink/tps61060.pdf
Kenny
PostPosted: Wed Jun 14, 2006 4:57 pm     Reply with quote
LM317L connected in constant current mode, an old trick.
http://www.onsemi.com/pub/Collateral/AND8109-D.PDF
SherpaDoug
PostPosted: Wed Jun 14, 2006 8:21 pm     Reply with quote
My favorite for driving one or two LEDS from 12V just uses a bipolar transistor (2N3904) and a resistor if your PIC voltage is regulated. Drive the base from the PIC pin and connect a resistor (220 Ohms for 20mA and VCC=5V) from the emitter to GND. Then connect the LEDs in series from +12V to the collector. Three LEDs may have a problem if the LED voltage is high or the +12V is low. You will have to do the math for your application. Things will drift a little with temperature, but not enough for the eye to see.
Humberto
PostPosted: Thu Jun 15, 2006 6:33 am     Reply with quote
The key for this is to use a constant current source that deliver the expected constant 20mA AND a couple of voltage comparator wired as window comparator that enable the whole functioning only if the battery voltage is within an expected adjustable range, ie:
An upper comparator that watch if the battery voltage is under Vmax(adj).
A lower comparator that watch if the battery voltage is over Vmin(adj).
Each comparator with open colector output and OR wired with a pull up resistor tied from 5V. If the battery voltage is outside of the expected value, the comparator output will generate a Shut-Down level to switch off the whole circuit.
This way the circuit should keep a constant brightness of the LED's regardless of the battery voltage drops.
Humberto
