		| View previous topic :: View next topic   |
			VanHauser
  Joined: 03 Oct 2005 Posts: 88 Location: Ploiesti, Romania
				| printf() odd behavior with floats |
				 Posted: Fri May 19, 2006 4:39 am     |
				I'm using PCH 3.249. The printf() function does not seem to format %f fields correctly. This is my test code, on 18F252:
 	  | Code: | 	 		     printf("%f\r\n", 0.0001);
   printf("%f\r\n", 12.0);
   printf("%f\r\n", 9999.0);
   printf("%f\r\n", -13.25);
   printf("%f\r\n", 13.45);
   printf("%f\r\n", -1999.0);
   printf("%f\r\n", -0.000035);
   printf("%f\r\n", -9999.0); |
And this is what I get:
 	  | Code: | 	 		  0.000100
12.000000
1409.065987
-13.250000
13.450000
-1999.000064
-0.000035
-1409.065987 |
9999.0 and -9999.0 are not displayed correctly    Some advice, anyone? |
				 Posted: Fri May 19, 2006 11:50 am     |
				This is a known bug with the "%f" format specifier.    To fix it, you need
to put in the width and precision fields.   Also, the width field must be
greater than the precision field.
It's best if you always put in the width and precision fields.
Don't use the plain "%f" specifier.
 	  | Quote: |
#include <16F877.H>
printf("%7.5f\r\n", 9999.0);
printf("%7.5f\r\n", -9999.0);
References:
http://www.ccsinfo.com/forum/viewtopic.php?t=26059&start=6
http://www.ccsinfo.com/forum/viewtopic.php?t=24719&start=1 |
