printf() odd behavior with floats
VanHauser
PostPosted: Fri May 19, 2006 4:39 am     Reply with quote
I'm using PCH 3.249. The printf() function does not seem to format %f fields correctly. This is my test code, on 18F252:
   printf("%f\r\n", 0.0001);
   printf("%f\r\n", 12.0);
   printf("%f\r\n", 9999.0);
   printf("%f\r\n", -13.25);
   printf("%f\r\n", 13.45);
   printf("%f\r\n", -1999.0);
   printf("%f\r\n", -0.000035);
   printf("%f\r\n", -9999.0);
And this is what I get:
12.000000
1409.065987
-13.250000
13.450000
-1999.000064
-0.000035
-1409.065987
9999.0 and -9999.0 are not displayed correctly Shocked Some advice, anyone?
PostPosted: Fri May 19, 2006 11:50 am     Reply with quote
This is a known bug with the "%f" format specifier. To fix it, you need
to put in the width and precision fields. Also, the width field must be
greater than the precision field.
It's best if you always put in the width and precision fields.
Don't use the plain "%f" specifier.
#include <16F877.H>
printf("%7.5f\r\n", 9999.0);
printf("%7.5f\r\n", -9999.0);
References:
http://www.ccsinfo.com/forum/viewtopic.php?t=26059&start=6
http://www.ccsinfo.com/forum/viewtopic.php?t=24719&start=1
