Oscar Guest
problem with port D |
Posted: Wed Mar 22, 2006 12:45 pm |
I need to work with port D to send a information to beams of but my I cosay for some reason does not do it, please help me. I leave this I cosay them apparently here very simple to catch and to off the port but does not do it, Thanks reason why can do and if they can place again I cosay improved serious fantastic...
#include <18F4620.h>
#device adc=8
#fuses NOWDT,WDT128,HS, NOPROTECT, IESO, BROWNOUT, BORV21, NOPUT, NOCPD, NOSTVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOEBTR, NOCPB, NOEBTRB, NOWRTC, NOWRTB, NOFCMEN, NOXINST, NOPBADEN, NOLPT1OSC, NOMCLR
#define output_d
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
while (1)
output_d(0x00);
output_d(0xff);
Posted: Wed Mar 22, 2006 12:57 pm |
cosay for some reason does not do it, |
Get rid of the #define statement shown in bold below. Delete it.
#device adc=8
#define output_d
Oscar Guest
still I have errors |
Posted: Wed Mar 22, 2006 1:26 pm |
I did it but still I have errors, is not sufficient. I continue having problems |
Posted: Wed Mar 22, 2006 1:34 pm |
I deleted that line and compiled your program with no errors.
I did this with the PCH compiler, version 3.245. |
Oscar Guest
still I have errors please help me... |
Posted: Thu Mar 23, 2006 7:29 am |
Excuse which happens is that I have Plug-in of Mplab and when I suppress this line presents/displays errors to me, and I have version 3,203 of the CCS and also gives errors me. Please help me with this... |
