Himax/HX8312A
Himax/HX8312A
PostPosted: Mon Mar 13, 2006 9:19 am     Reply with quote
Does anybody knows if CCS has support for this controller ?
PostPosted: Tue Mar 21, 2006 2:28 am     Reply with quote
Can someone please help / point me where can i get infos regarding software LCD control for this controller LSI : HX8312-A
THANK YOU !
rberek
PostPosted: Tue Mar 21, 2006 8:24 am     Reply with quote
There is very little about this controller on the web. I found this document which references it.
http://www.edtc.com/EDT/Products/Specs/348.pdf
All, I know is that it has both an SPI and CPU interface. For more than that, I suggest you contact Himax directly.
PostPosted: Tue Mar 21, 2006 11:34 am     Reply with quote
Thank you rberek !
I dont know where you find this infos :-) but now i have some bacis idea how this works...
Hmm. then there should be no problem, controling it thru CCS ?
Maybe with some changed version of GLCD ?
rberek
PostPosted: Tue Mar 21, 2006 12:04 pm     Reply with quote
Google...
Well, there should be no problem COMMUNICATING with it. I think you'd still need more info on how to control it. Without more details on the command/data sequences that the control expects, I couldn't say how hard it is to control it. Himax should be able to give you some info.
And if CCS doesn't have a driver for it, write your own and put it in the code library!
Good Luck..
