Guest Guest
Himax/HX8312A |
Posted: Mon Mar 13, 2006 9:19 am |
Does anybody knows if CCS has support for this controller ? |
Guest Guest
Posted: Tue Mar 21, 2006 2:28 am |
Can someone please help / point me where can i get infos regarding software LCD control for this controller LSI : HX8312-A
THANK YOU ! |
rberek
Joined: 10 Jan 2005 Posts: 207 Location: Ottawa, Canada
Posted: Tue Mar 21, 2006 8:24 am |
There is very little about this controller on the web. I found this document which references it.
http://www.edtc.com/EDT/Products/Specs/348.pdf
All, I know is that it has both an SPI and CPU interface. For more than that, I suggest you contact Himax directly. |
Posted: Tue Mar 21, 2006 11:34 am |
Thank you rberek !
I dont know where you find this infos :-) but now i have some bacis idea how this works...
Quote: | All, I know is that it has both an SPI and CPU interface. |
Hmm. then there should be no problem, controling it thru CCS ?
Maybe with some changed version of GLCD ? |
rberek
Posted: Tue Mar 21, 2006 12:04 pm |
Quote: | I dont know where you find this infos :-) |
Google...
Well, there should be no problem COMMUNICATING with it. I think you'd still need more info on how to control it. Without more details on the command/data sequences that the control expects, I couldn't say how hard it is to control it. Himax should be able to give you some info.
And if CCS doesn't have a driver for it, write your own and put it in the code library!
Good Luck.. |
