ADN
software RS232 problem! help! |
Posted: Thu Feb 16, 2006 11:11 am |
I am using a PIC18F2550 which has a software R232-connection to the PC. I want that the RS232 waits till it gets 8 characters from the PC.
This is my code:
#use rs232(baud=57600, bits=8,parity=n,xmit=PIN_A1, rcv=PIN_A2, stream=commu)
#byte TRISA = 0xF92
bit_clear(TRISA,1);
bit_set(TRISA,2);
RB_counter=0;
while (RB_counter<8)
while(!kbhit(commu));
if (kbhit(commu))
alps_in_data[RB_counter]=fgetc(commu);
delay_us(1);
RB_counter=RB_counter+1;
I thought the pic would wait at the line while(!kbhit(commu)); till it gets a new character but I habe seen the pic does not stop at that positon and read 8 NULL values, without that the PC has sent any thing!
I am really at loss and need urgently your help!
Thx in advance!! |
Humberto
Posted: Thu Feb 16, 2006 11:56 am |
If the loop doesn't stop, it seems something wrong with the Rcv input.
At first glance I see that the pins used are Digital I/O or Analog Inputs.
After power up, they wake up as Analog Inputs unless other specification.
Add this in the beggining:
setup_adc_ports(NO_ANALOGS);
Made some changes in the polling..
RB_counter=0;
do
// wait here...
}while(!kbhit(commu));
if (kbhit(commu))
if (RB_counter>8)
RB_counter=0;
// read the received packet
Humberto
ADN
Posted: Thu Feb 16, 2006 12:03 pm |
I have already added this command
so it is obviously not the cause of the problem
ADN |
Humberto
Posted: Thu Feb 16, 2006 12:14 pm |
PIN_A2 should be high when idle, did you check this ?
Humberto |
ADN
Posted: Thu Feb 16, 2006 12:19 pm |
Quote: |
RB_counter=0;
do
// wait here...
if (kbhit(commu))
if (RB_counter>8)
RB_counter=0;
but I think this does not change any thing, in the fact that the "while(!kbhit(commu)); " loop does not wait for an incoming character. |
ADN
Posted: Thu Feb 16, 2006 12:21 pm |
Humberto wrote: | PIN_A2 should be high when idle, did you check this ?
Humberto |
yes I have checked this and both pins A1 and A2 are high |
Posted: Thu Feb 16, 2006 12:26 pm |
What does the rest of your RS-232 interface look like? Do you use an interface chip like the MAX-232? |
Posted: Thu Feb 16, 2006 12:27 pm |
Quote: | but I think this does not change any thing, in the fact that the "while(!kbhit(commu)); " loop does not wait for an incoming character. | The software UART is level sensitive and sees a logic 0 as the start bit, this as opposed to a hardware UART which is edge sensitive and would wait for the high-to-low edge. |
ADN
Posted: Thu Feb 16, 2006 12:33 pm |
ckielstra wrote: | What does the rest of your RS-232 interface look like? Do you use an interface chip like the MAX-232? |
exactly, I am using MAX232 |
Posted: Thu Feb 16, 2006 12:43 pm |
Which compiler version are you using? It might be a compiler bug.
Does your program work when you move the receive PIN_A2 to a pin on another port, for example port B? |
ADN
Posted: Thu Feb 16, 2006 12:51 pm |
ckielstra wrote: | Which compiler version are you using? It might be a compiler bug.
I am using the PCWH version of CCSC.
Actually I did not try to choose an other pin on another port. But this is a good idea. I will try it out.
ADN |
Humberto
ADN wrote:
Yes it does. kbhit() wait for the start bit of an incoming character.
Is the only way to wait for a start bit using software UART. At @57600 Baud -as you are using- the start bit is 17us long.
When asking something, pls post full info. We doesn't know how did you set the
18 configuration bits that determine the main behaviour of this processor.
Humberto
ADN
Posted: Thu Feb 16, 2006 12:57 pm |
sorry Humbrto, you r right!
here are the fuses I am using and the different setup commands:
//#FUSES WDT128 //Watch Dog Timer uses 1:128 Postscale
#FUSES XTPLL //Crystal/Resonator with PLL enabled
//#FUSES BORV20 //Brownout reset at 2.0V
#FUSES NOLVP //No Low Voltage Programming on B3(PIC16) or B5(PIC18)
//#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES PLL1 //No PLL PreScaler
#FUSES USBDIV
#FUSES VREGEN
#use delay(clock=48000000)
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(VREF_LOW|-2);
setup_low_volt_detect(FALSE);
setup_oscillator(False);
setup_spi(spi_master |spi_clk_div_4 |SPI_L_TO_H | SPI_XMIT_L_TO_H);
hope it helps find out the mistake!
ADN |
Humberto
Posted: Thu Feb 16, 2006 1:28 pm |
What kind of crystal are you using ? I mean serial / paralel cut.
Mmmh.. did you make a sofware delay test to make sense of how fast the PIC is running?
Humberto |
ADN
Posted: Thu Feb 16, 2006 1:41 pm |
I am using a 4 Mhz crystal. And it works smoothly. |
