ERROR (drives crazy) ---> Expecting a close paren
PravinP
PostPosted: Sat Jan 21, 2006 12:37 pm     Reply with quote
Dear Members,
I am using PIC10F200
i have the following definition in my file
#define ENABLE PIN_B0
when i compile the code with
if(input(ENABLE))
output_high(ENABLE);
i get error message "Expecting a close paren"
Its really driving me crazy because i cannot read my input port pin. I have even tried using if(input(PIN_B0)), but still the same error.
Please share ur views on whats going wrong
Pravin
PostPosted: Sat Jan 21, 2006 12:56 pm     Reply with quote
Try to use another word in place of ENABLE.
Humberto
PostPosted: Sat Jan 21, 2006 6:14 pm     Reply with quote
Do not know what do you try to do with:
     if(input(ENABLE))
but anyway, I tested the following code using the reserved(?) word ENABLE
selected as option in the preprocessor directive #use RS232(...) and then as an output
pin name.
#include <10F200.h>
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOPROTECT                //Code not protected from reading
#use rs232(baud=9600,xmit=PIN_B1,rcv=PIN_B2,ENABLE=PIN_B3)
#use fast_io(B)
  do
     if(input(ENABLE))
     putc('A');
    }while(1);
...................      if(input(ENABLE))
003F:  BTFSS  PORTB.0
0040:  GOTO   043
....................         output_high(ENABLE);
0041:  BSF    PORTB.0
....................         break;
0042:  GOTO   047
....................      putc('A');
0043:  MOVLW  TMR0
0044:  MOVWF  ??65535
0045:  GOTO   @PUTCHAR_1_
It compiled properly, no warning, no error.
Humberto
PravinP
PostPosted: Sun Jan 22, 2006 3:18 am     Reply with quote
sorry made some errors while posting the code
The define file is
#define ENB PIN_B0
#define INP PIN_B3
delay_ms(DELAY);
if(input(INP))
output_high(ENB);
I am scanning the port pin PIN_B3 for high, if i sense a high on the pin, i exit the loop
But i get the same error "Expecting a close paren" after i compile the code.
Is there anyother method by which i can sense the port pin instead of using the build in function.
(eg. in 8051, i can simply write if (INP == 1))
Thanks,
Pravin
Brian S
PostPosted: Sun Jan 22, 2006 9:01 am     Reply with quote
if ( input(PIN_B4) == 1 ) /*Start Sequencing on B4 hi*/
Cheers!
PostPosted: Sun Jan 28, 2007 3:09 pm     Reply with quote
if( input_state(pin_b4)) "== sequence" isnt necessary . its also boolean true
PostPosted: Sun Jan 28, 2007 3:54 pm     Reply with quote
You didn't post a full test program. It's really important to do that
when you're getting compiler errors. I took your code fragments
and made the test program below. It compiles with no errors with
PCB vs. 3.249.
#include <10F200.h>
#fuses NOWDT, NOMCLR
#define ENB PIN_B0
#define INP PIN_B3
#define DELAY 1
   delay_ms(DELAY);
   if(input(INP))
      output_high(ENB);
