		| Author | Message |
		| PravinP
				| ERROR  (drives crazy) ---> Expecting a close paren |
				|  Posted: Sat Jan 21, 2006 12:37 pm |   |
				| Dear Members, I am using PIC10F200
 i have the following definition in my file
 #define   ENABLE   PIN_B0
 when i compile the code with
 if(input(ENABLE))
 output_high(ENABLE);
 i get error message "Expecting a close paren"
 Its really driving me crazy because i cannot read my input port pin. I have even tried using  if(input(PIN_B0)), but still the same error.
 Please share ur views on whats going wrong
 Pravin
		| Guest
				|  Posted: Sat Jan 21, 2006 12:56 pm |   |
				| Try to use another word in place of ENABLE. |  |
		| Humberto
				|  Posted: Sat Jan 21, 2006 6:14 pm |   |
				| Do not know what do you try to do with:
  	  | Code: |  	  | if(input(ENABLE))
 but anyway, I tested the following code using the reserved(?) word ENABLE
 selected as option in the preprocessor directive #use RS232(...) and then as an output
 pin name.
  	  | Code: |  	  | #include <10F200.h>
 #FUSES NOWDT                    //No Watch Dog Timer
 #FUSES MCLR                     //Master Clear pin enabled
 #FUSES NOPROTECT                //Code not protected from reading
 #use rs232(baud=9600,xmit=PIN_B1,rcv=PIN_B2,ENABLE=PIN_B3)
 #use fast_io(B)
 do
 if(input(ENABLE))
 putc('A');
 }while(1);
  	  | Code: |  	  | ...................      if(input(ENABLE))
 003F:  BTFSS  PORTB.0
 0040:  GOTO   043
 ....................         output_high(ENABLE);
 0041:  BSF    PORTB.0
 ....................         break;
 0042:  GOTO   047
 ....................      putc('A');
 0043:  MOVLW  TMR0
 0044:  MOVWF  ??65535
 0045:  GOTO   @PUTCHAR_1_
 It compiled properly, no warning, no error.
 Humberto
		| PravinP
				|  Posted: Sun Jan 22, 2006 3:18 am |   |
				| Hi, sorry made some errors while posting the code
 The define file is
 #define   ENB	PIN_B0
 #define   INP	PIN_B3
 delay_ms(DELAY);
 if(input(INP))
 output_high(ENB);
 I am scanning the port pin PIN_B3 for high, if i sense a high on the pin, i exit the loop
 But i get the same error "Expecting a close paren" after i compile the code.
 Is there anyother method by which i can sense the port pin instead of using the build in function.
 (eg.  in 8051, i can simply write if (INP  == 1))
 Thanks,
 Pravin
		| Brian S
				|  Posted: Sun Jan 22, 2006 9:01 am |   |
				| if ( input(PIN_B4) == 1 )  /*Start Sequencing on B4 hi*/ {
 Cheers!
		| Guest
				|  Posted: Sun Jan 28, 2007 3:09 pm |   |
				| if( input_state(pin_b4)) "== sequence" isnt necessary . its also boolean true |  |
		| PCM programmer
				|  Posted: Sun Jan 28, 2007 3:54 pm |   |
				| You didn't post a full test program.   It's really important to do that when you're getting compiler errors.   I took your code fragments
 and made the test program below.   It compiles with no errors with
 PCB vs. 3.249.
 #fuses NOWDT, NOMCLR
 #define ENB PIN_B0
 #define INP PIN_B3
 #define DELAY 1
 delay_ms(DELAY);
 if(input(INP))
 output_high(ENB);
