Timer0 and WDT
Marionco
Timer0 and WDT
PostPosted: Tue Nov 29, 2005 8:18 pm     Reply with quote
Hi guys.
I am using a 18F4620 and CCS 3.235.
Can I use Timer 0 (I´m using if for making a time base of aprox 1sec) and use the watchdog timer as to avoid any hangup, both at the same time ?
Any help will be appreciated.
Marionco.
drolleman
PostPosted: Tue Nov 29, 2005 11:21 pm     Reply with quote
yes the wdt is separate from the timer0 the only time the wdt fires, is if it times out. timer 0 is for your use as a second counter will work fine
PostPosted: Wed Nov 30, 2005 5:29 pm     Reply with quote
Thanks a lot, drolleman.
MARIONCO.-
