Kevin Benedict Guest
LCD.C problem |
Posted: Sat Jun 07, 2003 1:59 pm |
Usind LCD.C and getting error
Error[28] C:\PROJECTS\F84FANSW\LCD.C 139 : Expecting an identifier
Which is the first line of
void lcd_putc( char c) {
switch (c) {
case '\f' : lcd_send_byte(0,1);
delay_ms(2);
case '\n' : lcd_gotoxy(1,2); break;
case '\b' : lcd_send_byte(0,0x10); break;
default : lcd_send_byte(1,c); break;
Any suggestions ?
___________________________
Original Post ID: 144515087 |
Re: LCD.C problem |
Posted: Sat Jun 07, 2003 10:47 pm |
:=Usind LCD.C and getting error
:=Error[28] C:\PROJECTS\F84FANSW\LCD.C 139 : Expecting an identifier
:=Which is the first line of
:=void lcd_putc( char c) {
Can you tell us:
1. The name and version of your compiler.
2. The part number of the PIC you are using.
To try and duplicate your problem, I can compile the CCS
example, EX_LCDKB.C, which uses the LCD.C file. Do you
get that error when you compile that example file ?
I just need to verify that, before I test it.
Original Post ID: 144515088 |
Re: LCD.C problem |
Posted: Sun Jun 08, 2003 8:02 pm |
Dumb mistake on my part, I was using some borrowed code and
C was define as the carry flag bit in another include file,
so the compiler did not like "lcd_putc( char c)"
I have corrected the #define statement.
Thanks for the help !
:=:=Usind LCD.C and getting error
:=:=Error[28] C:\PROJECTS\F84FANSW\LCD.C 139 : Expecting an identifier
:=:=Which is the first line of
:=:=void lcd_putc( char c) {
:=Can you tell us:
:=1. The name and version of your compiler.
:=2. The part number of the PIC you are using.
:=To try and duplicate your problem, I can compile the CCS
:=example, EX_LCDKB.C, which uses the LCD.C file. Do you
:=get that error when you compile that example file ?
:=I just need to verify that, before I test it.
Original Post ID: 144515099 |
