wmeade
MAX7219 LED Driver Help needed... |
Posted: Mon Oct 20, 2003 1:28 pm |
I am trying to drive 2 7 segment leds using a 16F877 with a MAX7219 LED Display Driver chip using PICC SPI Drivers. I have done a search of the forum and found 4 references that I have used to accomplish this. I am only getting the decimal points to blink when I turn on the proto-board. My code is below and any help will be greatly appreciated. All I am trying to do in the program is put a number '8' on LED 0.
As you can see in the setup_spi line, I had to use comas and not the | between the Parameters. Why is this? Is that why it is not working?
#include <16F877.H> // processor include file
#fuses HS,NOWDT,PUT,PROTECT,BROWNOUT,NOLVP,WRT // set fuses
#use delay(clock=20000000) // set processor speed 20 MHz
#define max_clk pin_c3 // set pin clock is using
#define max_dout pin_c5 // set pin data in is using
#define max_cs pin_b2 // set pin load/cs is using
output_low(max_clk); // set clock line low
output_low(max_din); // set data line in low
output_high(max_cs); // set load/cs line low
output_float(max_din); // set pin as input
setup_adc_ports(NO_ANALOGS);
setup_psp(PSP_DISABLED);
setup_spi(SPI_MASTER, SPI_L_TO_H, SPI_XMIT_L_TO_H, SPI_CLK_DIV_16);
setup_7219()
// set number of LED displays to use
output_low(max_cs); // set cs line low
spi_write(0x0B); // point to the Scan Register
spi_write(0x05); // send 1, (Two LED Displays 0-1)
output_high(max_cs); // set cs line high
// set LED intensity to 50%
spi_write(0x0A); // point to the Intensity Register
spi_write(0x05); // send 5, (LED 50% brightness)
// set BCD Decoding
spi_write(0x09); // point to Decode Mode Register
spi_write(0x03); // decode LED 0 and 1
// turn off test mode
spi_write(0x0F); // point to Display Test Register
spi_write(0x00); // turn off test mode
main()
setup_7219();
// display a '8' on LED 0
spi_write(0x001); // point to LED (0) Register
spi_write(0x08); // send '8'
Mark
Posted: Mon Oct 20, 2003 2:25 pm |
The setup_spi() is a function call. It should go inside a routine. The way you have it, the compiler thinks that it is a function prototype, thus the error when you compiled with the "|". Yes it should be "|". You should also have an endless loop in your main to prevent the processor from executing a hidden sleep command. I didn't check your code but I made corrections where I know there were problems.
setup_7219()
// set BCD Decoding
main()
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_XMIT_L_TO_H | SPI_CLK_DIV_16);
setup_7219();
cxiong
MAX7219 Does not work |
Posted: Tue Dec 28, 2004 11:56 am |
I have found this post in the forum and I try it, it does not work.
I just does not turn on the LED at all. I use the LDQ-N512RI with
the Max7219. I just need to drive the first 2 digit according to this post.
I modified the code to use my 4Mhz, and pin RC5 to max_din, and max_cs
to pin RC0.
Here is my code:
Code: | #include <16F877.H> // processor include file
#fuses XT,NOLVP // set fuses
#use delay(clock=4000000) // set processor speed 4 MHz
#define max_din pin_c5 // set pin data in is using
#define max_cs pin_c0 // set pin load/cs is using
setup_7219()
// set BCD Decoding
main()
output_low(max_cs); // set load/cs line low
setup_7219();
spi_write(0x01); // point to LED (0) Register
Did you have your code above working? |
max7219 |
Posted: Tue Dec 28, 2004 1:14 pm |
Here is the latest code I have. I have the code to display 8405 on digit 0-3. It does not display the 8405, it display a.a.a.a. on the LED. and I can't control the intensity of the display by low the the hex under register address: 0x0A.
Here is my code: Code: | #include <16f877.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
setup_7219()
delay_us(1);
delay_us(1);
spi_write(0x03); // send 4, (Four LED Displays 0-3)
delay_us(1);
delay_us(1);
delay_us(1);
spi_write(0x01); // send 5, (LED 50% brightness)
delay_us(1);
output_low(max_cs); // set cs line high
// set BCD Decoding
delay_us(1);
delay_us(1);
spi_write(0x0F); // decode LED 0 - 3
delay_us(1);
delay_us(1);
delay_us(1);
spi_write(0x01); // turn off test mode
delay_us(1);
main()
output_low(max_clk); // set clk line low
delay_us(1);
delay_us(1);
output_high(max_cs); // set load/cs line high
delay_us(1);
setup_spi(SPI_MASTER|SPI_L_TO_H |SPI_XMIT_L_TO_H|SPI_CLK_DIV_4|SPI_SAMPLE_AT_END);
setup_7219();
delay_us(1);
delay_us(1);
// display a '4' on LED 1
spi_write(0x02); // point to LED (0) Register
delay_us(1);
spi_write(0x04); // send '8'
delay_us(1);
// display a '0' on LED 2
spi_write(0x03); // point to LED (0) Register
delay_us(1);
spi_write(0x00); // send '8'
delay_us(1);
// display a '5' on LED 3
spi_write(0x04); // point to LED (0) Register
delay_us(1);
spi_write(0x05); // send '8'
delay_us(1);
Any body can help me? |
drh
Joined: 12 Jul 2004 Posts: 192 Location: Hemet, California USA
Posted: Wed Dec 29, 2004 9:32 am |
Read the datasheet for the MAX7219 again.
The code for 50% intensity is 0x07.
The part is in shutdown at powerup. Why are you taking it out of test mode?
Use Code: |
spi_write(0x0C); // shutdown register
spi_write(0x01); // normal operation
In your while loop you are setting the CS line high when it should be low and low when it should be high. _________________ David |
wlasoi@saci.ubu.ac.th Guest
try my code, it easy to understand. |
Posted: Fri Feb 04, 2005 3:31 am |
#include<18f452.h>
#fuses xt,nowdt,put,noprotect
#define da pin_c0
#define cs pin_c1
#define clk pin_c2
void send_16bit(byte address,byte data)
byte i;
#bit carry=0x03.0;
carry=0;
output_low(cs);
for(i=0;i<8;i++)
if((address & 0b10000000)==0)
output_low(da);
output_high(da);
rotate_left(&address,1);
output_high(clk);
delay_us(50);
output_low(clk);
delay_us(50);
for(i=0;i<8;i++)
if((data & 0b10000000)==0)
output_low(da);
output_high(da);
rotate_left(&data,1);
output_high(clk);
delay_us(50);
output_low(clk);
delay_us(50);
output_high(cs);
void init_7219()
send_16bit(0x09,0xff); //decode
delay_us(100);
send_16bit(0x0a,0x0f); //intensity
delay_us(100);
send_16bit(0x0b,0x07); //scan limit
delay_us(100);
send_16bit(0x0c,0x01); //shutdown
delay_us(100);
send_16bit(0x0f,0x00); //display
delay_us(100);
main()
int i,j;
set_tris_c(0x00);
init_7219();
while(1){
for(i=1;i<=8;i++){
for(j=0;j<=9;j++){
send_16bit(i,j);
delay_ms(200);
Max7219 |
Posted: Mon Aug 29, 2005 8:51 am |
I want to display the result of ADC result into the 7-segments in decimal,
example 0-255.
How do I separate these numbers such as one, tenth, hundredth out from
the ADC result and display them in the 7-segments.
I have been searching for a very simple way (theory) how to do it, I can't
one that simple enough for me to understand.
Any body give me a direction or a simple theory (explanation) how to do that?
Thanks... |
Mark
Posted: Mon Aug 29, 2005 9:17 am |
Well the simplest way would be to divide by 10. The remainder would be the digit.
int8 number,digit1,digit10,digit100;
// Get the number
number = get_adc();
// Compute the 1's
digit1 = number % 10;
number /= 10;
// Compute the 10's
digit10 = number % 10;
number /= 10;
// The rest is the 100's
digit100 = number;
Posted: Mon Aug 29, 2005 10:03 am |
Hi Mark
I just want clear
example, the adc result is equal to 123
is the above code which divide by 10 will work?
my calculation is
123 / 10 = 12 remainder 3 (3 is the digit1)
123 / 10 = 12 remainder 3 (so the digit10 is also 3?)
Can you explain little bit?
Thanks.. |
treitmey
Posted: Mon Aug 29, 2005 10:22 am |
He is using the /= so the result is the previous result divided by 10
result=123/10=12 R3
result=12/10 =1 R2
result=1/10 = 0 R1
your interested in the remainder
Its like hacking off a digit at a time. hack off 3 then 2 then 1 |
cxiong
Posted: Tue Aug 30, 2005 2:26 pm |
How do I display the ds1307 (hh:mm) into the 7-segment using max7219?
What is the best way to do it? Theory? |
Posted: Thu Sep 01, 2005 7:10 am |
Can not display the hour and minutes digits into 7-segment.
My questions are:
1. I can not initialize both of the ds1307 and max7219, I think they are
conflict when I run the init_7219(); and the init_ds1307();
in my main code because both use the RC3, RC4 pins.
2. I can not think of a way to single out the following min into minh
and minl, and single out the hrs into hrh and hrl so I can display
their individual digit into their proper location on the 7-segments.
Quote: | min = gca_ds1307_regs[DS1307_MINUTES_REG];
hrs = gca_ds1307_regs[DS1307_HOURS_REG]; |
I would be great appreciate if anyone can help.
I welcome any input or suggestion..
Thanks...........
Here is my main.c code
Code: | ////////////////////////////////////////////////////////////////////////////////
// The LOAD/CS of the MAX7219 was LOW Active
#include <18F452.h>
#device ADC=10
//#use i2c(Master, SDA=PIN_B7, SCL=PIN_B6)
#use i2c(Master, SDA=PIN_B4, SCL=PIN_B3)
#use i2c(Master, SDA=PIN_c4, SCL=PIN_c3)
#include <max7219_ds1307.c>
#include <ds1307.c>
unsigned char hrh,hrl,minh,minl;
void init_ds1307()
// Put some date and time values into the global date & time array.
gca_ds1307_regs[DS1307_SECONDS_REG] = 0; // 0 seconds
gca_ds1307_regs[DS1307_MINUTES_REG] = 14; // 10 minutes
gca_ds1307_regs[DS1307_HOURS_REG] = 8; // 8 AM
gca_ds1307_regs[DS1307_DAY_OF_WEEK_REG]= 0; // Skip this.
gca_ds1307_regs[DS1307_DATE_REG] = 04; // 3 rd
gca_ds1307_regs[DS1307_MONTH_REG] = 01; // Jan
gca_ds1307_regs[DS1307_YEAR_REG] = 05; // 2005
// Write these values to the DS1307, for testing.
ds1307_set_date_time();
//********* Main Program Start Here **********/////
int second;
int minute;
int hours;
int dates;
int months;
int year;
char sec;
char min;
char hrs;
char day;
char date;
char month;
char yr;
init_ds1307();
setup_adc_ports( ALL_ANALOG );
setup_adc( ADC_CLOCK_INTERNAL );
output_high(max_load); // set load/cs line high
setup_spi(SPI_MASTER|SPI_L_TO_H |SPI_XMIT_L_TO_H|SPI_CLK_DIV_4);
init_7219(); // Initialize MAX7219 Value
hrh =0;
hrl =0;
minh=0;
minl=0;
write_time(hrh,hrl,minh,minl);
output_low(max_load); // set load line LOW
output_high(max_load); // set load line high
ds1307_read_date_time();
// Get these into variables with shorter names, so I can
// put them into printf more easily.
sec = gca_ds1307_regs[DS1307_SECONDS_REG];
day = gca_ds1307_regs[DS1307_DAY_OF_WEEK_REG];
date = gca_ds1307_regs[DS1307_DATE_REG];
month = gca_ds1307_regs[DS1307_MONTH_REG];
yr = gca_ds1307_regs[DS1307_YEAR_REG];
And here is my include file max7219_ds1307.c
//// max7219_ds1307.C ////
//// Driver for Max7219 (8-bit 7-segment display ////
//// init_7219() Must be called before any other function. ////
//// write_dig(a,b,c,d) Will write the number (char) to digit 1-4 ////
//// The following have special meaning: ////
//// hrh = 1st digit ////
//// hrl = 2nd digit ////
//// minh = 3rd digit ////
//// minl = 4th digit ////
//// ** Digits are order from left to right ////
#define max_load pin_c0 // set pin load/cs is using
void init_7219()
spi_write(0x1B); // point to the Scan Register
spi_write(0x1A); // point to the Intensity Register
// set BCD Decoding
spi_write(0x19); // point to Decode Mode Register
void write_time(unsigned char hrh,unsigned char hrl, unsigned char minh, unsigned char minl)
// dig1
spi_write(hrh); // send '1'
// dig2
spi_write(hrl); // send '1'
// dig3
spi_write(minh); // send '7'
// dig4
spi_write(minl); // send '7'
delay_ms(4);
Posted: Thu Sep 01, 2005 7:11 am |
My questions are:
Thanks...........
#include <18F452.h>
#device ADC=10
#include <ds1307.c>
void init_ds1307()
int second;
int minute;
int hours;
int dates;
int months;
int year;
char sec;
char min;
char hrs;
char day;
char date;
char month;
char yr;
init_ds1307();
hrh =0;
hrl =0;
minh=0;
minl=0;
void init_7219()
// set BCD Decoding
// dig1
// dig2
// dig3
// dig4
delay_ms(4);
Posted: Thu Sep 01, 2005 7:12 am |
My questions are:
Thanks...........
#include <18F452.h>
#device ADC=10
#include <ds1307.c>
void init_ds1307()
int second;
int minute;
int hours;
int dates;
int months;
int year;
char sec;
char min;
char hrs;
char day;
char date;
char month;
char yr;
init_ds1307();
hrh =0;
hrl =0;
minh=0;
minl=0;
void init_7219()
// set BCD Decoding
// dig1
// dig2
// dig3
// dig4
delay_ms(4);
Posted: Thu Sep 01, 2005 7:16 am |
I am sorry for the tripple post, every time I click the submit button, it
show an error, I thought it did not successful, so I did click it 3 times and it display the same message 3 times.
Sorry. |
