MAX7219 LED Driver Help needed...
Goto page 1, 2  Next
wmeade
PostPosted: Mon Oct 20, 2003 1:28 pm     Reply with quote
I am trying to drive 2 7 segment leds using a 16F877 with a MAX7219 LED Display Driver chip using PICC SPI Drivers. I have done a search of the forum and found 4 references that I have used to accomplish this. I am only getting the decimal points to blink when I turn on the proto-board. My code is below and any help will be greatly appreciated. All I am trying to do in the program is put a number '8' on LED 0.
As you can see in the setup_spi line, I had to use comas and not the | between the Parameters. Why is this? Is that why it is not working?
#include <16F877.H>                                            // processor include file
#fuses HS,NOWDT,PUT,PROTECT,BROWNOUT,NOLVP,WRT                 // set fuses
#use delay(clock=20000000)                                     // set processor speed 20 MHz
#define max_clk      pin_c3                                    // set pin clock is using
#define max_dout      pin_c5                                    // set pin data in is using
#define max_cs       pin_b2                                    // set pin load/cs is using
output_low(max_clk);                                             // set clock line low
output_low(max_din);                                            // set data line in low
output_high(max_cs);                                             // set load/cs line low
output_float(max_din);                                          // set pin as input
setup_adc_ports(NO_ANALOGS);
setup_psp(PSP_DISABLED);
setup_spi(SPI_MASTER, SPI_L_TO_H, SPI_XMIT_L_TO_H, SPI_CLK_DIV_16);
setup_7219()
   // set number of LED displays to use
   output_low(max_cs);                                         // set cs line low
   spi_write(0x0B);                                            // point to the Scan Register
   spi_write(0x05);                                            // send 1, (Two LED Displays 0-1)
   output_high(max_cs);                                        // set cs line high
   // set LED intensity to 50%
   spi_write(0x0A);                                            // point to the Intensity Register
   spi_write(0x05);                                            // send 5, (LED 50% brightness)
   // set BCD Decoding
   spi_write(0x09);                                            // point to Decode Mode Register
   spi_write(0x03);                                            // decode LED 0 and 1
   // turn off test mode
   spi_write(0x0F);                                            // point to Display Test Register
   spi_write(0x00);                                            // turn off test mode
main()
   setup_7219();
   // display a '8' on LED 0
   spi_write(0x001);                                             // point to LED (0) Register
   spi_write(0x08);                                            // send '8'
Mark
PostPosted: Mon Oct 20, 2003 2:25 pm     Reply with quote
The setup_spi() is a function call. It should go inside a routine. The way you have it, the compiler thinks that it is a function prototype, thus the error when you compiled with the "|". Yes it should be "|". You should also have an endless loop in your main to prevent the processor from executing a hidden sleep command. I didn't check your code but I made corrections where I know there were problems.
setup_7219()
   // set BCD Decoding
main()
  setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_XMIT_L_TO_H | SPI_CLK_DIV_16);
   setup_7219();
cxiong
MAX7219 Does not work
PostPosted: Tue Dec 28, 2004 11:56 am     Reply with quote
I have found this post in the forum and I try it, it does not work.
I just does not turn on the LED at all. I use the LDQ-N512RI with
the Max7219. I just need to drive the first 2 digit according to this post.
I modified the code to use my 4Mhz, and pin RC5 to max_din, and max_cs
to pin RC0.
Here is my code:
#fuses XT,NOLVP                                          // set fuses
#use delay(clock=4000000)                                      // set processor speed 4 MHz
#define max_din      pin_c5                                    // set pin data in is using
#define max_cs       pin_c0                                    // set pin load/cs is using
setup_7219()
   // set BCD Decoding
main()
  output_low(max_cs);                                             // set load/cs line low
   setup_7219();
         spi_write(0x01);                                            // point to LED (0) Register
Did you have your code above working?
max7219
PostPosted: Tue Dec 28, 2004 1:14 pm     Reply with quote
Here is the latest code I have. I have the code to display 8405 on digit 0-3. It does not display the 8405, it display a.a.a.a. on the LED. and I can't control the intensity of the display by low the the hex under register address: 0x0A.
Here is my code:
#include <16f877.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
setup_7219()
   delay_us(1);
   delay_us(1);
      spi_write(0x03);                                            // send 4, (Four LED Displays 0-3)
   delay_us(1);
   delay_us(1);
   delay_us(1);
      spi_write(0x01);                                            // send 5, (LED 50% brightness)
   delay_us(1);
      output_low(max_cs);                                        // set cs line high
   // set BCD Decoding
   delay_us(1);
   delay_us(1);
      spi_write(0x0F);                                            // decode LED 0 - 3
   delay_us(1);
   delay_us(1);
   delay_us(1);
      spi_write(0x01);                                            // turn off test mode
   delay_us(1);
main()
    output_low(max_clk);                                            // set clk line low
   delay_us(1);
   delay_us(1);
     output_high(max_cs);                                             // set load/cs line high
   delay_us(1);
   setup_spi(SPI_MASTER|SPI_L_TO_H |SPI_XMIT_L_TO_H|SPI_CLK_DIV_4|SPI_SAMPLE_AT_END);
      setup_7219();
      delay_us(1);
      delay_us(1);
      // display a '4' on LED 1
         spi_write(0x02);                                            // point to LED (0) Register
      delay_us(1);
         spi_write(0x04);                                            // send '8'
      delay_us(1);
      // display a '0' on LED 2
         spi_write(0x03);                                            // point to LED (0) Register
      delay_us(1);
         spi_write(0x00);                                            // send '8'
      delay_us(1);
      // display a '5' on LED 3
         spi_write(0x04);                                            // point to LED (0) Register
      delay_us(1);
         spi_write(0x05);                                            // send '8'
      delay_us(1);
Any body can help me?
drh
PostPosted: Wed Dec 29, 2004 9:32 am     Reply with quote
Read the datasheet for the MAX7219 again.
The code for 50% intensity is 0x07.
The part is in shutdown at powerup. Why are you taking it out of test mode?
Use
   spi_write(0x0C);  // shutdown register
   spi_write(0x01);  // normal operation
In your while loop you are setting the CS line high when it should be low and low when it should be high.
David
wlasoi@saci.ubu.ac.th
try my code, it easy to understand.
PostPosted: Fri Feb 04, 2005 3:31 am     Reply with quote
#include<18f452.h>
#fuses xt,nowdt,put,noprotect
#define da pin_c0
#define cs pin_c1
#define clk pin_c2
void send_16bit(byte address,byte data)
byte i;
#bit carry=0x03.0;
carry=0;
output_low(cs);
for(i=0;i<8;i++)
if((address & 0b10000000)==0)
output_low(da);
output_high(da);
rotate_left(&address,1);
output_high(clk);
delay_us(50);
output_low(clk);
delay_us(50);
for(i=0;i<8;i++)
if((data & 0b10000000)==0)
output_low(da);
output_high(da);
rotate_left(&data,1);
output_high(clk);
delay_us(50);
output_low(clk);
delay_us(50);
output_high(cs);
void init_7219()
send_16bit(0x09,0xff); //decode
delay_us(100);
send_16bit(0x0a,0x0f); //intensity
delay_us(100);
send_16bit(0x0b,0x07); //scan limit
delay_us(100);
send_16bit(0x0c,0x01); //shutdown
delay_us(100);
send_16bit(0x0f,0x00); //display
delay_us(100);
main()
int i,j;
set_tris_c(0x00);
init_7219();
while(1){
for(i=1;i<=8;i++){
for(j=0;j<=9;j++){
send_16bit(i,j);
delay_ms(200);
Max7219
PostPosted: Mon Aug 29, 2005 8:51 am     Reply with quote
I want to display the result of ADC result into the 7-segments in decimal,
example 0-255.
How do I separate these numbers such as one, tenth, hundredth out from
the ADC result and display them in the 7-segments.
I have been searching for a very simple way (theory) how to do it, I can't
one that simple enough for me to understand.
Any body give me a direction or a simple theory (explanation) how to do that?
Thanks...
Mark
PostPosted: Mon Aug 29, 2005 9:17 am     Reply with quote
Well the simplest way would be to divide by 10. The remainder would be the digit.
  int8 number,digit1,digit10,digit100;
  // Get the number
  number = get_adc();
  // Compute the 1's
  digit1 = number % 10;
  number /= 10;
  // Compute the 10's
  digit10 = number % 10;
  number /= 10;
  // The rest is the 100's
  digit100 = number;
PostPosted: Mon Aug 29, 2005 10:03 am     Reply with quote
Hi Mark
I just want clear
example, the adc result is equal to 123
is the above code which divide by 10 will work?
my calculation is
123 / 10 = 12 remainder 3 (3 is the digit1)
123 / 10 = 12 remainder 3 (so the digit10 is also 3?)
Can you explain little bit?
Thanks..
treitmey
PostPosted: Mon Aug 29, 2005 10:22 am     Reply with quote
He is using the /= so the result is the previous result divided by 10
result=123/10=12 R3
result=12/10 =1 R2
result=1/10 = 0 R1
your interested in the remainder
Its like hacking off a digit at a time. hack off 3 then 2 then 1
cxiong
PostPosted: Tue Aug 30, 2005 2:26 pm     Reply with quote
How do I display the ds1307 (hh:mm) into the 7-segment using max7219?
What is the best way to do it? Theory?
PostPosted: Thu Sep 01, 2005 7:10 am     Reply with quote
Can not display the hour and minutes digits into 7-segment.
My questions are:
1. I can not initialize both of the ds1307 and max7219, I think they are
conflict when I run the init_7219(); and the init_ds1307();
in my main code because both use the RC3, RC4 pins.
2. I can not think of a way to single out the following min into minh
and minl, and single out the hrs into hrh and hrl so I can display
their individual digit into their proper location on the 7-segments.
min = gca_ds1307_regs[DS1307_MINUTES_REG];
hrs = gca_ds1307_regs[DS1307_HOURS_REG];
I would be great appreciate if anyone can help.
I welcome any input or suggestion..
Thanks...........
Here is my main.c code
//   The LOAD/CS of the MAX7219 was LOW Active
#include <18F452.h>
#device ADC=10
//#use i2c(Master, SDA=PIN_B7, SCL=PIN_B6)
#use i2c(Master, SDA=PIN_B4, SCL=PIN_B3)
#use i2c(Master, SDA=PIN_c4, SCL=PIN_c3)
#include <max7219_ds1307.c>
#include <ds1307.c>
unsigned char hrh,hrl,minh,minl;
void init_ds1307()
   // Put some date and time values into the global date & time array.
   gca_ds1307_regs[DS1307_SECONDS_REG] = 0; // 0 seconds
   gca_ds1307_regs[DS1307_MINUTES_REG] = 14; // 10 minutes
   gca_ds1307_regs[DS1307_HOURS_REG] = 8; // 8 AM
   gca_ds1307_regs[DS1307_DAY_OF_WEEK_REG]= 0; // Skip this.
   gca_ds1307_regs[DS1307_DATE_REG] = 04; // 3 rd
   gca_ds1307_regs[DS1307_MONTH_REG] = 01; // Jan
   gca_ds1307_regs[DS1307_YEAR_REG] = 05; // 2005
   // Write these values to the DS1307, for testing.
   ds1307_set_date_time();
//*********  Main Program Start Here **********/////
   int second;
   int   minute;
   int hours;
   int dates;
   int months;
   int year;
   char sec;
   char min;
   char hrs;
   char day;
   char date;
   char month;
   char yr;
   init_ds1307();
   setup_adc_ports( ALL_ANALOG );
   setup_adc( ADC_CLOCK_INTERNAL );
     output_high(max_load);                                     // set load/cs line high
   setup_spi(SPI_MASTER|SPI_L_TO_H |SPI_XMIT_L_TO_H|SPI_CLK_DIV_4);
      init_7219();                                     // Initialize MAX7219  Value
      hrh =0;
      hrl =0;
      minh=0;
      minl=0;
      write_time(hrh,hrl,minh,minl);
         output_low(max_load);                                       // set load line LOW
         output_high(max_load);                                      // set load line high
      ds1307_read_date_time();
      // Get these into variables with shorter names, so I can
      // put them into printf more easily.
      sec = gca_ds1307_regs[DS1307_SECONDS_REG];
      day = gca_ds1307_regs[DS1307_DAY_OF_WEEK_REG];
      date = gca_ds1307_regs[DS1307_DATE_REG];
      month = gca_ds1307_regs[DS1307_MONTH_REG];
      yr = gca_ds1307_regs[DS1307_YEAR_REG];
And here is my include file max7219_ds1307.c
////                             max7219_ds1307.C                              ////
////                 Driver for Max7219 (8-bit 7-segment display        ////
////  init_7219()   Must be called before any other function.           ////
////  write_dig(a,b,c,d)  Will write the number (char) to digit 1-4     ////
////                      The following have special meaning:           ////
////                      hrh = 1st digit                                  ////
////                      hrl = 2nd digit                               ////
////                      minh = 3rd digit                                ////
////                      minl = 4th digit                                 ////
////          ** Digits are order from left to right                                                          ////
#define max_load     pin_c0                                      // set pin load/cs is using
void init_7219()
      spi_write(0x1B);                                             // point to the Scan Register
      spi_write(0x1A);                                             // point to the Intensity Register
   // set BCD Decoding
      spi_write(0x19);                                            // point to Decode Mode Register
void write_time(unsigned char hrh,unsigned char hrl, unsigned char minh, unsigned char minl)
   // dig1
      spi_write(hrh);                                            // send '1'
   // dig2
      spi_write(hrl);                                            // send '1'
   // dig3
      spi_write(minh);                                            // send '7'
   // dig4
      spi_write(minl);                                            // send '7'
   delay_ms(4);
PostPosted: Thu Sep 01, 2005 7:11 am     Reply with quote
My questions are:
Thanks...........
#include <18F452.h>
#device ADC=10
#include <ds1307.c>
void init_ds1307()
   int second;
   int   minute;
   int hours;
   int dates;
   int months;
   int year;
   char sec;
   char min;
   char hrs;
   char day;
   char date;
   char month;
   char yr;
   init_ds1307();
      hrh =0;
      hrl =0;
      minh=0;
      minl=0;
void init_7219()
   // set BCD Decoding
   // dig1
   // dig2
   // dig3
   // dig4
   delay_ms(4);
PostPosted: Thu Sep 01, 2005 7:12 am     Reply with quote
My questions are:
Thanks...........
#include <18F452.h>
#device ADC=10
#include <ds1307.c>
void init_ds1307()
   int second;
   int   minute;
   int hours;
   int dates;
   int months;
   int year;
   char sec;
   char min;
   char hrs;
   char day;
   char date;
   char month;
   char yr;
   init_ds1307();
      hrh =0;
      hrl =0;
      minh=0;
      minl=0;
void init_7219()
   // set BCD Decoding
   // dig1
   // dig2
   // dig3
   // dig4
   delay_ms(4);
PostPosted: Thu Sep 01, 2005 7:16 am     Reply with quote
I am sorry for the tripple post, every time I click the submit button, it
show an error, I thought it did not successful, so I did click it 3 times and it display the same message 3 times.
Sorry.
Goto page 1, 2  Next
Page 1 of 2
