		| Author | Message |
		| young
				| applying a realtime clock to 16f877 |
				|  Posted: Wed Jul 27, 2005 1:44 pm |   |
				| I am developing a system that could record data as well as recording when it happened? please advice how to do it. |  |
		| young
				|  Posted: Wed Jul 27, 2005 2:00 pm |   |
				| Thank yu very much, can I have your #include "ds1820.c"   // external module
 #include "ds1307.c"   // external module
 please?
		| Ttelmah Guest
				|  Posted: Wed Jul 27, 2005 2:06 pm |   |
				| ds1302.c, comes with the compiler. try looking in the 'devices' dirctory.
		| young
				|  Posted: Wed Jul 27, 2005 2:07 pm |   |
				| thank you: I found ds1302.c in my computer under device folder.
		| Guest
				|  Posted: Thu Jul 28, 2005 2:01 am |   |
				|  	  | young wrote: |  	  | Thank yu very much, can I have your #include "ds1820.c"   // external module
 please?
 These files are in a single zipped file at the buttom of that page.
 Have you downloaded ?
		| arunb
				| RE: |
				|  Posted: Sun Jul 31, 2005 8:04 am |   |
				| Hi,
 Is a 32.768 khz watch crystal good enough???
 thanks
 arunb
		| Mark
				| Re: RE: |
				|  Posted: Sun Jul 31, 2005 8:48 am |   |
				|  	  | arunb wrote: |  	  | Hi,
 thanks
 arunb
 I think that you are going to have to elaborate a little more for young on what you mean.
 If you device is battery backed up or you can stand to lose the time settings on power up, you can drive the clock of one of the timers/counters and create your own clock.
		| arunb
				| RE: |
				|  Posted: Mon Aug 01, 2005 3:48 am |   |
				| Hi,
 What I mean is that ....if accuracy is not an issue then a watch crystal would be good enough to generate a timer interrupt every one second. , and if the application uses a PC to synchronise data or time then battery backup may also be eliminated....
 Just my opinion....
 thanks
 arunb
		| Mark
				| Re: RE: |
				|  Posted: Mon Aug 01, 2005 5:29 am |   |
 Just my opinion....
 thanks
 arunb
 One note.  If you use a watch crystal, then the accuracy will be very very good.  If accuracy is not an issue, then you could derive the time off the osc of the micro.  There are examples of this in the forum.
