applying a realtime clock to 16f877
young
PostPosted: Wed Jul 27, 2005 1:44 pm     Reply with quote
I am developing a system that could record data as well as recording when it happened? please advice how to do it.
young
PostPosted: Wed Jul 27, 2005 2:00 pm     Reply with quote
Thank yu very much, can I have your
#include "ds1820.c" // external module
#include "ds1307.c" // external module
please?
PostPosted: Wed Jul 27, 2005 2:06 pm     Reply with quote
ds1302.c, comes with the compiler. try looking in the 'devices' dirctory.
young
PostPosted: Wed Jul 27, 2005 2:07 pm     Reply with quote
thank you:
I found ds1302.c in my computer under device folder.
PostPosted: Thu Jul 28, 2005 2:01 am     Reply with quote
please?
These files are in a single zipped file at the buttom of that page.
Have you downloaded ?
arunb
RE:
PostPosted: Sun Jul 31, 2005 8:04 am     Reply with quote
Is a 32.768 khz watch crystal good enough???
thanks
arunb
Mark
Re: RE:
PostPosted: Sun Jul 31, 2005 8:48 am     Reply with quote
arunb wrote:
thanks
arunb
I think that you are going to have to elaborate a little more for young on what you mean.
If you device is battery backed up or you can stand to lose the time settings on power up, you can drive the clock of one of the timers/counters and create your own clock.
arunb
RE:
PostPosted: Mon Aug 01, 2005 3:48 am     Reply with quote
What I mean is that ....if accuracy is not an issue then a watch crystal would be good enough to generate a timer interrupt every one second. , and if the application uses a PC to synchronise data or time then battery backup may also be eliminated....
Just my opinion....
thanks
arunb
Mark
Re: RE:
PostPosted: Mon Aug 01, 2005 5:29 am     Reply with quote
arunb wrote:
Just my opinion....
thanks
arunb
One note. If you use a watch crystal, then the accuracy will be very very good. If accuracy is not an issue, then you could derive the time off the osc of the micro. There are examples of this in the forum.
