My program goes into the PORTB on change interrupt service routine, #INT_RB, even though I can't see any signals changing on these ports. I am using the CDC-library of CCS to send data via USB to the PC, but I can't find where CDC may be interfering with portB. Any suggestions?...
Do you mean that you get an INT_RB interrupt as soon as
you enable interrupts ?
If so, it's happening because you didn't clear the "change" condition
on Port B before you enabled interrupts.
You do this by reading port B.
#byte PortB = 6 // Address of Port B for the 16F series PICs
main()
char c;
port_b_pullups(true);
set_tris_b(0x10);
enable_interrupts(INT_RB);
c = PortB; // Read PortB before enabling global interrupts.
Mark
