On-Change Interrupt
alwaysfresh
On-Change Interrupt
PostPosted: Tue Jul 12, 2005 12:28 pm     Reply with quote
My program goes into the PORTB on change interrupt service routine, #INT_RB, even though I can't see any signals changing on these ports. I am using the CDC-library of CCS to send data via USB to the PC, but I can't find where CDC may be interfering with portB. Any suggestions?...
I use to setup port b pin b4:
port_b_pullups(true);
set_tris_b(0x10);
enable_interrupts(INT_RB);
Thanks,
Andy
PostPosted: Tue Jul 12, 2005 1:36 pm     Reply with quote
Do you mean that you get an INT_RB interrupt as soon as
you enable interrupts ?
If so, it's happening because you didn't clear the "change" condition
on Port B before you enabled interrupts.
You do this by reading port B.
#byte PortB = 6     // Address of Port B for the 16F series PICs
main()
char c;
set_tris_b(0x10);
c = PortB;    // Read PortB before enabling global interrupts.
Mark
PostPosted: Tue Jul 12, 2005 6:09 pm     Reply with quote
Read this->
http://www.ccsinfo.com/forum/viewtopic.php?t=23421&highlight=portb+output+interrupt
alwaysfresh
PostPosted: Wed Jul 13, 2005 7:47 am     Reply with quote
Works!... Thank you Mark your the best.
This morning I was starting to think the PIC's input at portB was broken or something. Safed again.
Andy
