		| Author | Message |
		| Neutone
				| Making a modbus formatted packet |
				|  Posted: Thu Mar 13, 2003 4:29 pm |   |
				| This is a way to create a modbus formatted packet of a fixed length. This function is formatted to send 4 bytes to a memmory address. This is a good way to monitor process variables over a serial port and it uses CRC16 error checking. I pickup good ideas in this forum all the time. It just feels like time to contribute something of substance.
 int8 PacketBuffer[10],x,z;
 int1 FlagXOR;
 PacketBuffer[0] = slave_address;
 PacketBuffer[1] = Function_code;
 PacketBuffer[2] = Address_lo;
 PacketBuffer[3] = Address_hi;
 PacketBuffer[4] = data0;
 PacketBuffer[5] = data1;
 PacketBuffer[6] = data2;
 PacketBuffer[7] = data3;
 PacketBuffer[8] = 0xff;             // Prepair CRC
 PacketBuffer[9] = 0xff;             // Prepair CRC
 for ( x=0; x < 8; x++ )
 {  z = PacketBuffer[x];
 PacketBuffer[8] ^= z;
 for ( y = 8; y > 0; y-- )
 {  FlagXOR = bit_test( PacketBuffer[8], 0 );
 shift_right( &PacketBuffer[8], 2, 0 );
 if ( FlagXOR )
 {  PacketBuffer[8]^=0x01;
 PacketBuffer[9]^=0xA0;
 ___________________________
 Original Post ID: 12642
		| Hans Wedemeyer Guest
				| Re: Modbus simulator available |
				|  Posted: Thu Mar 13, 2003 6:09 pm |   |
				| I found several simulators that generate/simulate a response as if it were a slave, but never found a master simulator.
 If anyone needs an small windows app to generate modbus messages and test them via RS-232.
 The program allows the user to select
 SLAVE ID
 MESSAGE ID
 enter ASCII text
 Generates check sum and send the message then wait for a response.
 It will find and use any RS-232 on a Windows 2000 system, should also work on XP and NT
 Program captures response from slave and displays it in Plain ASCII or Hex.
 Original Post ID: 12647
		| Guest
				|  Posted: Fri Jun 03, 2005 12:05 pm |   |
				| GOTO www.win-tech.com and they have demos for modbus master/slave testing and development. |  |
